GS400 Plugs 1999
Hi to Everyone!
I'm trying to change the plugs on my engine and I am having difficulty accessing the spark plugs after having removed the coil. There is a rubber insert, should I pull that out in order to access the plug? I tried pulling it out but don't want to use excessive force for fear of damaging it.
Any help would be greatly appreciated.
Alex
Alex
I'm sure others will correct me if I'm wrong, but the rubber insert (boot) actually connects to the coil. If it's down in the hole, see if you can twist it to free from the spark plug. Then you can pull it out. I was able to bend mine a fair amount without damaging the boot.
Thanks to both of you for such a quick reply. The other thing that puzzled was the spring that was inside the rubber booth, if it would have been just the rubber then I would have tried a little harder.
Thanks again
Alex
Thanks again
Alex
Hi!
Big mistake!!! Tried to pull out the rubber portion with needle nose pliers and the darn thing ripped in half. Put back the rubber portion back in the engine and of course the engine started
acting up. Took it out again and siliconed the two halves together and the engine is running fine.
There must be a special tool for such removals or am I the only one with such bad luck?
Alex
Alex
Originally Posted by Dx3
Changing plugs on our car is probably the easiest car in the world to do it.
Good luck,
Jonny
I personally thing Honda's 4cyl engines are the easiest. Pull out the spark plug wires and start removing the spark plugs
No need for one of those ball joint socket thingy.
But crap..it's probably the easiest V8 I've ever worked on. The worse is one of those Chevyor Dodge work van where their engines are half-way into the cabin
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
For the rubber to fuse onto the plug you would need faily high temperatures. I think the spring sitting on the plug is probably making it difficult for the rubber to come off. There is separation taking place between the rubber and the round metal wall that the whole coil-plug combo is sitting in.
Maybe spraying with some WD-40 might help loosen it?
Alex
Alex
I'm surprised by the lack of responses on this subject figuring it would be the easiest to have knowledge about, a simple tune up. I guess driving a Lexus puts one in a higher category of snob. Don't common folk drive expensive cars anymore?
Alex
Alex
Yes we're snobs.
Actually no. This is not a 24/7 service hotline so you can't expect instant response.
In addition, if the subject was easy to acknowledge about (a simple tune up), why haven't you figured out a solution?
Reason for the lack of response is not too many have had this problem before. During our tune-up, most people don't run into this problem.
Like I said there are still some nice people in this world, the others I would not give a plugged nickel for.
No I haven't got the plugs out because the same thing was happening in the three cylinders that I tried removing the plugs from, the rubber stayed behind in the well. I'm afraid of ripping the rubber portion again.
Thanks for the input
Alex
Alex
Alex
Alex
