Noise coming from a/c vents?
Has anyone experienced a clicking-like noise coming from inside the dash? It almost sounds like bb's roling around. It seems to have started with the warm weather? A/C maybe? Thanks!
pretty strange you bring this up..i thought i was goin nuts and my ac fan somehow just got louder out of no where...since earlier this spring...i wouldnt call it a clicking noise but it definitely sounds like a fan rotating and well yeah maybe "clicking" around louder then it should be.. and its never done this before with the air on in the past
Originally Posted by blk_lex_gs
GS3TEK, I have the same problem. Which coolant is low?
And coincidentally, my glove box was loose b/c I was working on some audio wiring and that made some weird felt/gravel noise too, but that can be heard towards the right side.
Originally Posted by GS3Tek
I'm telling you guys that it's possessed since 6-6-06 is coming
I had the same thing and it was low coolant
It sounds like gravel behind the center vent everytime you accelerate right?
Yeah, thats a good description. I will check the coolant levels. Thanks!
Gurgling or bubbling were also used to describe similar problems. Every now and then I hear chirping from the glovebox. I thought some birds got in there at first but Im not sure now
Mine is a faint whirring noise, kind of like crickets chirping in the distance or like the sound a CD player makes when it's scanning for a track on a CD. If I turn off the a/c button (even if the fan is still on), the noise stops. Is that what you guys have been experiencing?
Originally Posted by JLAM
yeh i have the same noise...it's kinda like a gurgle. I checked my coolant and it seems ok. It's not all the way to max but it's in between "low" and "full". Maybe I should try adding some to full mark.
I found the problem. It's a plugged A/C drain tube. See the post below for pics and directions.
https://www.clublexus.com/forums/sho...84#post1965184
Brian
Brian
