carfax help please....
hey guys,
can anyone please help me out on car fact check w/the following vehicle vin:
JT8BH68X1W0011747
thank you, truly appreciated.
william
JT8BH68X1W0011747
william
GOOD NEWS! Carfax search results confirm this 1998 Lexus GS400 (JT8BH68X1W0011747) qualifies for the $5,000 Clean Title History Guarantee. By ordering this Carfax Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
Section #: Section Name: Section Results:
Vehicle Specifications JT8BH68X1W0011747
1998 Lexus GS400
Title Check Clean Title History Guaranteed
Odometer Rollback Check No Odometer Rollback Detected
Problem Check No Problems Found
Registration Check Checked 7 types of vehicle registrations
Vehicle History Details 3 Total Vehicle History Records Found
NOTE: Carfax has not inspected this vehicle. It may have problems that have not been reported to Carfax.
How did Carfax analyze this vehicle's history?
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
Country Mfg.: JT8BH68X1W0011747
1998 Lexus GS400
4D Sedan Mid-size car
4.0L V8 MPI DOHC 24V
Gasoline
Rear-wheel drive
Normal
Japan
GOOD NEWS! Carfax search results confirm this 1998 Lexus GS400 (JT8BH68X1W0011747) qualifies for the Carfax $5,000 Clean Title History Guarantee. Carfax analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
Problems Checked: Results:
Salvage/Junk Title Checked - No Problem Found
Rebuilt/Reconstructed Title Checked - No Problem Found
Flood Damage Title Checked - No Problem Found
Damage Disclosure Checked - No Problem Found
Manufacturer Buyback (LEMON) Checked - No Problem Found
Exceeds Mechanical Limits Title Checked - No Problem Found
Not Actual Mileage Title Checked - No Problem Found
NOTE: Click here for a complete Carfax Glossary.
GOOD NEWS! Carfax search results on this 1998 Lexus GS400 (JT8BH68X1W0011747) did not uncover a potential odometer rollback. Carfax analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
Date Reported: Odometer Reading:
07/11/1998 7
GOOD NEWS! Carfax search results on this 1998 Lexus GS400 (JT8BH68X1W0011747) did not uncover any of the following problems:
Accident Records Checked - No Problem Found
Salvage Auction Records Checked - No Problem Found
Failed Emissions Inspection Checked - No Problem Found
Fire Damage Checked - No Problem Found
Crash Test Vehicle Checked - No Problem Found
Grey Market Vehicle Checked - No Problem Found
Carfax search results on this 1998 Lexus GS400 (JT8BH68X1W0011747) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Registrations Checked: Results:
Lease Checked - Lease Registration Found
Rental Checked - No Rental Registration Found
Government Checked - No Government Registration Found
Taxi Checked - No Taxi Registration Found
Fleet Checked - No Fleet Registration Found
Commercial Checked - No Commercial Registration Found
Non-Profit Checked - No Non-Profit Registration Found
The Carfax database contains a total of 3 vehicle history records on this 1998 Lexus GS400 (JT8BH68X1W0011747):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
08/03/1998 California
Motor Vehicle Dept.
Title issued
Registered as lease vehicle
Motor Vehicle Dept.
Registered as private lease vehicle
06/04/1999 7 California
Motor Vehicle Dept.
Hawthorne, CA
Title issued
Odometer reading recorded on 07/11/1998
NOTES:
You have significantly reduced your risk of purchasing a vehicle with a hidden problem. However, Carfax has not inspected this vehicle. There could be other potential problems with this vehicle that have not been reported to Carfax.
Not all titles issued represent a change in vehicle ownership. For example, a title could be issued to reflect an address change or correction.
PRINT AND SAVE THIS GUARANTEE ALONG WITH THE FULL REPORT
A Three-Year, Transferable Protection Plan
Carfax's $5,000 Guarantee confirms this 1998 Lexus GS400 (JT8BH68X1W0011747) has a Clean Title History. This certificate is valid for three years from date of issue, and is transferable!
Carfax $5,000 Clean Title History Guarantee Terms:
Vehicle ID Number (VIN): JT8BH68X1W0011747
Year/Make/Model: 1998 Lexus GS400
Issue Date:
09/23/2001
Expiration Date: 09/23/2004
Three-year Protection Plan:
During the next three years, should you discover a problem title in this vehicle's history which was not included in this Carfax Report, Carfax will pay you 10% of the vehicle's wholesale value - up to $5,000!
Transferable Protection:
This Guarantee is transferable should you sell this vehicle prior to the Guarantee expiration date. The new owner receives the same protection plan coverage for the balance of the Guarantee's term.
*Carfax agrees to pay to the holder of this report 10% of the wholesale value of the car, up to $5,000 if Section 2 of this report indicates a Clean Title History and a Problem Title actually exists for this vehicle. A Problem Title is defined as a passenger motor vehicle ownership document issued by the state that bears the word or symbol signifying that the vehicle was salvaged or junked; rebuilt or reconstructed; flood damaged; disclosed as damaged; bought back by the manufacturer; odometer exceeds mechanical limits; odometer was not the actual mileage; or any other symbol or word of like kind. Guarantee Certificate along with corresponding full report must be presented in order to be eligible for payment.
View complete Terms and Conditions.
1998 Lexus GS400
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
1998 Lexus GS400
Gasoline
Rear-wheel drive
Normal
Japan
07/11/1998 7
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
Motor Vehicle Dept.
Title issued
Motor Vehicle Dept.
Motor Vehicle Dept.
Hawthorne, CA
Title issued
NOTES:
Issue Date:
09/23/2001
