where did you mount your xbox
I mounted mine underneath the glovebox because I didnt want it to rattle apart in the trunk. Pretty soon I will remove the blue pieces and go back to black before I paint it to match the interior. Im also considering building some sort of casing for it now that I have it mounted that way even the bar doesnt show.
hey u guys should try to suspend it with some shock mountings or something to absorb some vibration and bumps so the harddrive can last a bit longer
since they are desktop hard drives and not the 2.5" laptop hard drives so they can only take so much pounding before bad sectors happen
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Registered User
with that said, I've had my Xbox (with a 250GB drive) in the coldest and hottest extremes here in Cleveland. From 0 degrees to 90 degrees (actually hotter since it was in trunk). And the only issue that I had was when the temperature was in the teens...the hard drive wasn't able to spin up 'til the ambient temperature in the trunk (where it was mounted) rose a bit.
Originally Posted by Tranman
Actually, if you check most of the carputer forums...most of the guys have their hard drives rigidly mounted...I'd say it would be a very small percentage that have had failures due to vibration. Personally, I would be worried about extreme temperatures...
Registered User
Originally Posted by Nolbi-Wan
i was thinking of mounting it in my trunk but didnt even realize that temp. would be an issue.
the xbox is so bulky that its kind of hard to mount it anywhere in the cabin because i want it hidden out of sight. i guess ill figure something out.
Well, it should be fine...the Xbox does have overheat protection and will shutoff if CPU temperatures go over 150 degrees....
Registered User
Originally Posted by Lexbox
Heat for me shouldnt be a problem for me anway as I have modified the cooling system a little. I pulled out the heatsinks and lapped them with 2000 grit sandpaper and they have a mirror smooth finish that results in more surface area touching the chips. I also bumped the voltage going to the fan and put Artic Silver 5 under both heatsinks. My Xbox rarely goes above 110F.
I watercooled my xbox in the house for a while but found that it wasnt really necessary. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Well, you also have the Xbox in the passenger cabin...which has circulating air unlike the trunk. On the hottest days around here, I've hit around 130-135 with it mounted in the trunk. When I go ahead and upgrade to a 400GB drive one of these days, I'll do the extra cooling mods to help it a bit.
sc300gte
Performance & Maintenance
05-17-07 11:22 AM
