Official JP/Quest/Wise/CarsonTuned LED Taillight Thread
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Originally Posted by slammed
any nice clear shots of the lights on a black gs? besides the one from (l-tunedparts.com)
![](http://www.somniplex.com/gallery/albums/DubShowCharlotteJune2006/IMG_3208.jpg)
![](http://www.somniplex.com/gallery/albums/DubShowCharlotteJune2006/IMG_3210.jpg)
![](http://www.somniplex.com/gallery/albums/DubShowCharlotteJune2006/MG_5372.jpg)
![](http://www.somniplex.com/gallery/albums/DubShowCharlotteJune2006/MG_5374.jpg)
dubsonlexus
Originally Posted by Hameed
It's very simple. I just yanked mine out as I replaced the actual brake light bulbs (both inner and outer) with 16-LED tower bulbs.
Here are instructions from BananaGS's website: http://lexusmodz.netfirms.com/
Tools:
- Small flat screw driver
- Philip screw driver.
- Step1: put in your key, low and extend the steering wheel down/away the dash as much as possible. Disconnect your battery leaving the steering wheel hanging out
-Step 2: gently pull the dash bezel out, just pull straight out
-Step 3: slide the dash bezel out, and disconnect the power cable attached to it
-Step 4: remove the 4 Philip screws as showed in the figure below then you can slide the dash instrument out, disconnect the 2 connectors attached to the panel.
Reinstall everything back in the reverse order.
You can replace broken light.... when you have the dash out
If you look at the second picture, you can clearly see the brake light warning bulb, remove the bolts as intsructed and just pull out the brake light warning bulb. It is the second one from the left on the bottom row.
![](http://lexusmodz.netfirms.com/GS_DIY/instrumentpanel/P1010022.JPG)
Tools:
thanks hameed for the info !!!
Originally Posted by DaveGS4
I took a couple on the Falken / JP car at the Dub Show in Charlotte
Hum................ should i or shouldn't i.... I wasn't sure how this will look on the black car, but actually it is not too bad... Will match up nicely with the 06 LED tail light on my SC!
Steve is the group buy price still available???
Am i the only one what doesn't really care for them.. I think the clear part is too large, I prefer the Original Jps. (obviously these are more practical). It doesn't look as bad on the black gs.. Btw that exhaust is sick looking on the Jp Gs.
J
J
Very bright light output, perfect fit, dashboard bulb removed, inner taillights replaced with crystal style - original Toyota OEM parts and D-CELL MATRIX FLASHING BRAKE LIGHT BULB LED bulb - http://autolumination.com/dcell5.html
EV ftw!!!
thx - more pics here - https://www.clublexus.com/forums/sho...=117989&page=4
i'm still searching for the link to those red crystal inner lights ...
it would be great to see a photo comparison of those crystal oem toyota inner lights the same way tlw did with the led tails when he got them.. shots side by side and then shots with them activated on the car side by side. they just don't look that diff from a distance?
