If you see his car in the lot. You should do something half-assed like he did. Pull off the wiper blades half way, or take off a few lugs off the rims and put them on the hood. If his car has hubcaps, pull them off and leave 3 the ground and keep one of them
screw that.. I say something like remove all the lugs from his car and wait for him, then when you see him.. start running to him and see if he takes off. That will definitely teach him a lesson the first time he trys to burn away.
If he finds him.. I say whip his *** and tell him he gives asians a bad name. I hate f'in theives.. cant do anything other than trying to make a quick buck. I bet that guys asian parents don't have a clue. (I am Korean fwiw.)
Damn asians and Honda owners. At least he didn't get them. He probably s@$t himself when he saw you coming.
Not cool man. I dont care if your asian or not, perpetuating stereotypes is one thing I hate. I know alot of good Asian people and some bad ones at well, just like any other race. Race has nothing to do with this issue.
I dont wanna have to get a new custom screwdriver to get the hex screws in. Is there an adaptive connecter with hex fittings on one side and phillips fitting on the other so that you can use the adapter as a key to remove hex screws using a regular phillips screwdriver????
I need this protective mod too. U think pepboys or autozone carries these? It sux that we have to watch our asses like this, it makes me sick.
i'm glad my fog lights are screwed in from the back of my bumper.
For those with stock bumpers.. get some Tamper Proof Screws. It's usually on electronics. Needs a special screwdriver with a hole in the center. They also make them in hex also with the stud in the center.
Ditto to that....I got Vertex kit....so fogs are secured from backside.
Yes...those screws or similar ones are the way to go for stock bumpers.
the gs fogs would fit on a eg civic with minor modification. So watch out for them. I'm going to modify mines TODAY! making sure no little kids gonna take them.
I went to homedepot today and found some 5mm hex heads work just fine maybe we shouldnt post up to much about this cause now the thief will carry a allen key set with him
