Platinum to Iridium... nice...
Well, i was in the shop today after work.. i originally brought the car in the shop to clean the throttle body, which i did.. and now the car idles so much better... But while i was there, i pulled a plug and found out that the previous owner put NGK platinum plugs in the car... i had a set of NGK iridiums that i bought a while back and decided to just throw them in... the car seems to be a little smoother now... now i just need to rebalance the wheels, and bring the coilovers down about another 1/2 inch and i think ill be set for a little bit........ till the Diamond amps get here
Originally Posted by corkycal
any big differences between iridium denso and ngk?
One time my budy who works in shop told me most Denso plugs are OEM by NGK. I think so far only NGK makes Iridum plugs, and a lot of dealer suggesting plug change at 90k because it is Iridum inside.
Besides, plugs are not that expensive and good for years. NGK Platium is around $9 per, and the Iridum one are around $15.
Originally Posted by josephdoc
I am not 100% sure but...
Im not sure about Denso plugs being OEM NGK's...
