90k timing belt / waterpump??
for the 90K service i plan to do the Timing belt and water pump on my own at a friends shop(only if i need to). a friend of mine brought up for the GS400 the timing belt can run up to 150K (of course it can vary depending on driver) and if timing belt snaps, it will not affect and damage other parts of the car. is this true?
I think the question he is asking is if the GS400 has an interference or nointerference motor.
Interference means that you'll grenade the motor if the timing belt snaps. Noninterference means you coast to a stop and call a tow truck and go replace the belt.
No words of wisdom from me beyond "search for interference motor" threads. Thats the answer.
Oh, and if you are going to tear into it to replace the timing belt, you might as well replae the waterpump wihle you're in there.
By saying that the valves will bend if the belt snaps while driving implies that the 1UZ-FE engine is an INTERFERENCE engine. The compression ratio is 10.5:1 which means that the piston has to be very close to the heads when it is at top dead center. The valves HAVE to be closed that time. If valves are down and the piston is up, there will be damage.
Hope that is clear enough. Wouldn't want you to have to rebuild your engine.
wow. i learned some new terms interference and nointerference motor.
i guess i will start preparing to change the timing belt and waterpump. i really didn't want to do it myself if i didn't have to cause it's waaayyyyyyyyyyy too much work. at the same time i dont want to spend $1000+ at a dealership. that could go towards bodykit find... i guess better safe then sorry.
Thanks Guys!!
Thanks Guys!!
Thanks Guys!!
Thanks Guys!!
oslouie
06-24-12 06:38 AM
gslover603
02-02-07 02:55 PM
