My 99 GS300 is Over Heating....................
Originally Posted by LEXSOOS
If so, you won't have any problems unless you don't know what are you doing.
I'm not sure about thermostat location on GS300 (i have GS400) so if you need more help just take a picture of it and post it so i can verify it for you, cool?
MAKE SURE TO TOP COOLANT OFF
Thanks again for your help!
![](http://img.photobucket.com/albums/v230/Cutthroat-trout/Misc%20Pics/Thermo1.jpg)
![](http://img.photobucket.com/albums/v230/Cutthroat-trout/Misc%20Pics/Thermo2.jpg)
Originally Posted by Cut-Throat
I took a couple of Pics. A closeup and one farther back. In reasearching the thermostat, it seems like the original equipment rating was 180 degrees. Do you happen to know a good place on-line that I can check this out?
Any on-line resources
I'll try and get a Thermostat in the next few days. After I replace it, I'll wait for a few hot days and see if this actually fixes the problem. I'll report my results on this thread, so if someone else has the same problem they'll know if this worked or not.
After you replace thermostat, just let the engine run alone for 30-45min, within that time keep your eye on temp. If everything is ok, take it for spin and see for yourself....you should be fine ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
An update:
Well, I replaced the thermostat this morning. A pretty easy job all in all. Only $20 for the thermostat and the O-ring gasket looked new and the parts fit like a watch! - Not like my old 65 Mustang, where the paper gasket was attached with a bunch of goo and the engine parts did not fit that precisely. The job took me about 25 minutes.
Unfortuantely, it did not fix my problem. I took the car out for a drive and got it heated up real good and came back to my driveway and let it idle for about 5 minutes in the 90 degree heat. Sure enough, the temperature gauge started creeping up past normal after about 5 minutes. I shut it off and think that my next stop will be the dealer. I think I covered all the cheap and easy remedies that I know about.
I'll continue to update this thread, in case anyone else runs into a similar problem.
Anybody want to venture a guess to what my solution is? The winner will most certainly have the respect of this forum
Originally Posted by GSteg
The problem is insufficient cooling.
did i win?
Perhaps it's the waterpump![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
__________________
![](http://img.photobucket.com/albums/v226/GSteg/clublexus-sig-1.jpg)
1999 Lexus GS400
-Stock
Your user account may not have sufficient privileges to access this page.![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
did i win?
__________________
1999 Lexus GS400
-Stock
Once again, overheating might be caused by:
1. Bad thermostat
2. Bad head gasket
3. Low coolant flow thru radiator
4. Foulty radiator temp. sensor
5. Not sufficient amount of coolant
6 Radiator fan running low rpm's
7. ?
I would sugest you to remove thermostat completly, and check if it is still overheating, if yes than take a trip to dealer, i guess
Thats all i can help you with, thru internet. Don't worry you'll fix this soon
Have you ever used any stop leak products in your radiator? Those can clog up your heater core and many other parts of your cooling system, and cause over heating.
Even if you have not used any stop leak products, try having your radiator flushed. Don't just drain it from the drain valve in the bottom of the radiator. Take it to a radiator shop that can actually flush it out, and install brand new RED Toyota/Lexus fluid. You'll most likely have to take a couple of bottles of your own fluid with you.
What about your oil situation? Do you have plenty of oil in the engine? When was it last changed? I'm just stabbing in the dark here to try to help you, but it seems like if you were running the car without enough oil, and/or it is dirty- that it could be contributing. Remember, this could be a combination of 2 or more problems, where one of the problems has been there for a while, but it wasn't bad enough to cause a problem- but now a second problem has come up and pushed it over the edge and caused it to overheat beyond an acceptable level. Try switching to full synthetic oil while you're at it, if you haven't already.
Good luck
Good luck
Good luck
Good luck
I have had this car since it was new and have babied it and pampered it for almost 8 years. Never have used anything like stopleak. Have had the radiator flushed on schedule. Plenty of oil and changes on schedule also.
Appreciate your comments, but I am thinking I have an issue like a water pump or fan speed problem.
This is really my first problem with this car in about 8 years of ownership, so I don't feel too bad. That is why I buy Lexus - Less problems. Thanks for your suggestions. I'll let you know
Agree to have a radiator repair shop test the flow through the radiator.
How many miles are on the vehicle?
When the coolant was replaced, was steam distilled water used with the 50/50 Mix?
If tap water was used, suspended minerals may clog the radiator.
Have the fan operations been checked?
What is the condition of rubber hoses? Inlet and return.
Over time, with heat, they become too soft and the walls collapse ... giving you restricted flow.
Also inpect the radiator front ... paper/card-board or junk may be clogging the fins.
Salim
Salim
Have you chanced the radiator caps yet? That should be the first thing to do on all cooling systems. Trust me, if that cap is messed up, it will suck in air into your cooling system as the antifreeze cools down, then cause air block when it heats up. Try that. I think you have air bubbles that are clogging your system.
I took the car out for a drive and shut off the A/C and sure enough, the car cooled down rather fast. But, as soon as stopped in my driveway with the A/C on and it was idling, the temperature gauge started rising again.
With AC on do both fans turn on?
Salim
Salim
