Vehicle Speed Sensor (VSS) HELP!!!
Hey guys,
Anyone have the Vehicle Speed Sensor diagram? I'm trying to install my Eclipse Unit and we all know how vital the speed sensor is to a navi unit.
Thanks in advance!
Oh and just in case, yes I did a search for this with no luck.
Thanks in advance!
Originally Posted by speedaddic
pull the gauge out, look at the plug that is connected to the gauge cluster and you'll see a little label that says #6.... Its not as hard as you're making it...really its not... haha would it help you if I told you the wire was GREEN?????
HELP!!!!!!
pm hameed and he can get you pics of the actual green wire. from what i heard, there are identical green wires on the harness and you have to tap into the correct one.
i would say if you tapped into one of the green wires and it didn't work, remove it and tap into the other wire and you're good to go.
Forum Administrator
Try this thread, is that what you're looking for?
https://www.clublexus.com/forums/sho...d.php?t=137443
tavarish
Performance & Maintenance
08-16-08 07:12 PM
