I have car fax for 1 month...
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
If anyone is planning on buying another car let me know... I can run the vin# for you for the next month on Car Fax.
The Ikon
The Ikon
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Will, your wish is my command...
Hey, if any one else need one, go to the SC forum and post request there... I'll get it sooner that way....... Since I check there often....
The Ikon
The Carfax database contains a total of 3 vehicle history records on this 1999 Lexus GS400 (JT8BH68X6X0014533):
Section #: Section Name: Section Results:
Vehicle Specifications JT8BH68X6X0014533
1999 Lexus GS400
Title Check Clean Title History Guaranteed
Odometer Rollback Check No Odometer Rollback Detected
Problem Check No Problems Found
Registration Check Checked 7 types of vehicle registrations
Vehicle History Details 3 Total Vehicle History Records Found
NOTE: Carfax has not inspected this vehicle. It may have problems that have not been reported to Carfax.
How did Carfax analyze this vehicle's history?
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
Country Mfg.: JT8BH68X6X0014533
1999 Lexus GS400
4D Sedan Mid-size car
4.0L V8 MPI DOHC 24V
Gasoline
Rear-wheel drive
Normal
Japan
GOOD NEWS! Carfax search results confirm this 1999 Lexus GS400 (JT8BH68X6X0014533) qualifies for the Carfax $5,000 Clean Title History Guarantee. Carfax analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
Problems Checked: Results:
Salvage/Junk Title Checked - No Problem Found
Rebuilt/Reconstructed Title Checked - No Problem Found
Flood Damage Title Checked - No Problem Found
Damage Disclosure Checked - No Problem Found
Manufacturer Buyback (LEMON) Checked - No Problem Found
Exceeds Mechanical Limits Title Checked - No Problem Found
Not Actual Mileage Title Checked - No Problem Found
NOTE: Click here for a complete Carfax Glossary.
GOOD NEWS! Carfax search results on this 1999 Lexus GS400 (JT8BH68X6X0014533) did not uncover a potential odometer rollback. Carfax analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
Date Reported: Odometer Reading:
11/24/1998 33
GOOD NEWS! Carfax search results on this 1999 Lexus GS400 (JT8BH68X6X0014533) did not uncover any of the following problems:
Accident Records Checked - No Problem Found
Salvage Auction Records Checked - No Problem Found
Failed Emissions Inspection Checked - No Problem Found
Fire Damage Checked - No Problem Found
Crash Test Vehicle Checked - No Problem Found
Grey Market Vehicle Checked - No Problem Found
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
12/07/1998 California
Motor Vehicle Dept.
Title issued
Registered as lease vehicle
Motor Vehicle Dept.
Registered as commercial vehicle
10/12/1999 33 California
Motor Vehicle Dept.
Los Angeles, CA
Title issued
Odometer reading recorded on 11/24/1998
The Ikon
1999 Lexus GS400
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
1999 Lexus GS400
Gasoline
Rear-wheel drive
Normal
Japan
11/24/1998 33
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
Motor Vehicle Dept.
Title issued
Motor Vehicle Dept.
Motor Vehicle Dept.
Los Angeles, CA
Title issued
Ikon - That's very cool of you to share...thanks!
Will - You know that you can just go to your local Lexus dealer and get a complete service printout of the car too...
Manaray this is true, but on a car alil' older it is a must. Plus a dealer may not have the info on an accident if a person takes the car to another body shop instead of a dealer. There are some shady people out there... I ran a car fax for another member on CL and the car had FLOOD damage.
The owner was lying about the car conditioning and it was a 97 ES3 with 43K miles on it... Better safe than sorry...
The Ikon
The Ikon
![Arrow](https://www.clublexus.com/forums/images/icons/icon2.gif)
GOOD NEWS! Carfax search results confirm this 1998 Lexus LS400 (JT8BH28F2W0122713) qualifies for the $5,000 Clean Title History Guarantee. By ordering this Carfax Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
Vehicle Specifications JT8BH28F2W0122713
1998 Lexus LS400
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
Country Mfg.: JT8BH28F2W0122713
1998 Lexus LS400
4D Sedan Large car
Gasoline
Rear-wheel drive
Normal
Japan
GOOD NEWS! Carfax search results confirm this 1998 Lexus LS400 (JT8BH28F2W0122713) qualifies for the Carfax $5,000 Clean Title History Guarantee. Carfax analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
GOOD NEWS! Carfax search results on this 1998 Lexus LS400 (JT8BH28F2W0122713) did not uncover a potential odometer rollback. Carfax analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
04/18/1998 18
08/31/2000 33,644
GOOD NEWS! Carfax search results on this 1998 Lexus LS400 (JT8BH28F2W0122713) did not uncover any of the following problems:
Carfax search results on this 1998 Lexus LS400 (JT8BH28F2W0122713) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Registrations Checked: Results:
Lease Checked - Lease Registration Found
Rental Checked - No Rental Registration Found
Government Checked - No Government Registration Found
Taxi Checked - No Taxi Registration Found
Fleet Checked - No Fleet Registration Found
Commercial Checked - Commercial Registration Found
Non-Profit Checked - No Non-Profit Registration Found
The Carfax database contains a total of 3 vehicle history records on this 1998 Lexus LS400 (JT8BH28F2W0122713):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
03/11/1998 Texas
Motor Vehicle Dept.
Houston, TX
Registered as commercial lease vehicle
04/18/1998 18 Texas
Motor Vehicle Dept.
Houston, TX
Title #10131235890151118
Title or registration issued
08/31/2000 33,644 Texas
Inspection Station
Houston, TX
Passed emissions inspection
1998 Lexus LS400
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
1998 Lexus LS400
4D Sedan Large car
Gasoline
Rear-wheel drive
Normal
Japan
04/18/1998 18
08/31/2000 33,644
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
03/11/1998 Texas
Motor Vehicle Dept.
Houston, TX
04/18/1998 18 Texas
Motor Vehicle Dept.
Houston, TX
Inspection Station
Houston, TX
Hey Thomas,
Could you run this VIN for me:
2C3HH56F0RH325927
This was the Intrepid I traded when I leased the GS back in 2000 so I am curious to see where it ended up..
Much thanks in advance!
Ken
2C3HH56F0RH325927
Ken
Savvy, there was not data available at this time...
The only info was... 1994 Chrysler/Intrepid ES (Canada)/3.5L V6 SMPI OHC 24V
Maybe because it is a Canadian car
I'm not sure...
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
VIN:
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
Country Mfg.: JT8BH68X3W0002726
1998 Lexus GS400
Gasoline
Rear-wheel drive
Normal
Japan
GOOD NEWS! Carfax search results confirm this 1998 Lexus GS400 (JT8BH68X3W0002726) qualifies for the Carfax $5,000 Clean Title History Guarantee. Carfax analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
GOOD NEWS! Carfax search results on this 1998 Lexus GS400 (JT8BH68X3W0002726) did not uncover a potential odometer rollback. Carfax analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
11/09/1997 42
08/12/1999 52,240
08/12/1999 49,018
GOOD NEWS! Carfax search results on this 1998 Lexus GS400 (JT8BH68X3W0002726) did not uncover any of the following problems:
Carfax search results on this 1998 Lexus GS400 (JT8BH68X3W0002726) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Lease Checked - No Lease Registration Found
Commercial Checked - No Commercial Registration Found
The Carfax database contains a total of 5 vehicle history records on this 1998 Lexus GS400 (JT8BH68X3W0002726):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
12/16/1997 42 California
Motor Vehicle Dept.
Title issued
Odometer reading recorded on 11/09/1997
12/16/1997 California
Motor Vehicle Dept.
Registered as private vehicle
08/12/1999 California
Motor Vehicle Dept.
Title issued
Ownership transfer reported
08/12/1999 52,240 California
Inspection Station
Woodland Hills, CA
08/17/1999 49,018 California
Motor Vehicle Dept.
Anaheim, CA
Title issued
Odometer reading recorded on 08/12/1999
Yr/Make/Model:
Body:
Engine:
Fuel:
Driveline:
Aspiration:
1998 Lexus GS400
Gasoline
Rear-wheel drive
Normal
Japan
11/09/1997 42
08/12/1999 52,240
08/12/1999 49,018
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
Motor Vehicle Dept.
Title issued
Motor Vehicle Dept.
Motor Vehicle Dept.
Title issued
Inspection Station
Woodland Hills, CA
Motor Vehicle Dept.
Anaheim, CA
Title issued
