Vsc Light On
Today I had a pain in my body - can anyone tell me what it is>>>???
OK, sarcasm is over. There are about 400 trouble codes that is could be - so unless you go to autozone and run an OBDII scan then noone can help.
WHen you do that, give me your code and I will tell you the problem.
Jonny
Something weird just happened today . . I started my car and the light was gone. To double check, i drove around town for about 10 miles and no light popped up. This kinda scares me . .
If its out it might of had to reset I took a fuse out once and my check engine light came on went to the dealer said they had to charge to check didnt have the time then told them will bring it the next day the light went out never had a problem sense that was 2 yrs ago
