what to check for when buying used gs300
im planning on getting a gs300 this weekend. price is good and from what the dealer said the car is clean. but you know how that goes.
they show a carfax that was run for the car and nothing came up.
but i was reading another post and someone said to check the vin sticker on the doors,hood,andfender?. anyone know any speicifics and what else to look for? thanks in advance.
things I check when I check out a car...
places for vin:
+ under hood
+ bottom outside corner of front doors
+ outer edge of rear doors
+ behind carpet on trunk lid liner
+ on door sill of driver's side door
+ stamped on the firewall facing the engine bay
+ inside lip of front fenders along the rubber strip that shields the engine from the elements.
check each piece of glass to see if each piece has the toyota name on it. if it doesn't, it may have been swapped with a cheaper replacement. of course - it could have been replaced but if it's with factory glass - great. don't forget the moonroof.
check the AC and blow the hot air full blast to see if it smells. maybe the previous owner was a smoker?
check the cabin filter to see if it's been changed, see if you see any mildew...
tire wear, cupping? uneven wear?
spare tire? is it different than the rest of the wheels?
is the metal under the carpet in the trunk a diff color than the rest of the car?
you can pull up the rear seat w/o making a big fuss and see if there is anything suspicious under it... water damage, odd welds, diff paint, etc... coins.
gently close each door and see if the door closes nicely and almost by itself. this will help to see if things are not aligned properly.
if you can - test drive it and have someone drive behind you to see if the car is driving properly down the road - no doglegging (where the rear wheels don't follow the front wheels properly) if it does dogleg, you're riding in a car with a bent frame.
test EVERYTHING. naturally.
ask for all service records, check the vin with local lexus and toyota dealerships. maybe they have records.
that's all i can think of now.
places for vin:
+ under hood
hopefully the smell will be coming from the cabin air filter. you can easily change that and it's located behind the glove box.
1) open glove box
2) remove rectangular piece on the back edge of it.
3) pull back rectangular piece of plastic that has cylindrical handles
4) pull back light grey rectangular tray towards you. There's a little tab to grab on to and it should slide right out.
Change it out and and throw an air freshener in your glove box and you'll be ok in a month.
1) open glove box
2003lx470
07-24-09 08:21 PM
