Navigation not working properly, any ideas?
Here's a pic I took a minute ago. I'm too lazy to unbolt the ECU, but it looks the same on the ECU end.
I'm not sure if the connector on the plug is friend also. Is there any way I can take the wire out of the plug, and "refresh" it with new parts? I see no way of getting the wire out of the damn plug.
Wow... that looks like it was exposed to water or some other liquid.
You can pull the wires out of the plug but you have to use a very small rod to push a plastic tab that holds each pin into place in the connector. A very small screwdriver (flat head) will do the job.
Come to think of it, I did see rustish water. But all this happened like 2 years ago though, lol. I just never went around to asking about it, lol.
The rest of the navi brain is working. So I'm not sure if the speed sensor is just not going through or what's up. Like mentioned I took the dip and bought another ECU, so hope it fixes it :/
Well I bought another ECU. It didn't came with the ECU so ok, I swapped mine over. It boots up fine, but the same problem is still there.
I'll try to pull the whole harness out I guess. I saw a thread on here to convert non-navi to navigation. So I guess I'll try to follow that and work backwards.
andyamp
12-05-16 07:59 PM
rahuldeo9
02-08-15 12:26 PM
slowmotion
09-23-03 11:44 AM
