Fricken Clickin!
Fricken Clickin!
I have searched the forums but can’t find an answer. I have a CLICK (wait 4-5 seconds) CLICK (wait 4-5 seconds) CLICK (wait 4-5 seconds)etc, noise coming from behind the radio/temperature control/dash area. Air condition is not on, Dual control is not on, “mode” is in the vent/feet mode. Anyone have any ideas.
Besides turning up the radio louder!
Thanks
Dakrri
Thanks
Dakrri
When I asked this same question, I was told it was low fluid in the radiator causing air bubbles in my cooling system. I topped it off with quick fill and it seemed to help, but now its back in full force. The fluids are still at full and the noise is loud as its ever been. I hope somebody finds the cure to this soon!
Thats exactly what it sounds like, "cumputing behind/in the dash" lmao!
My question is will the fluid not flow up and out if the thermostat temp is up and the fan is running? The cap says not to remove when hot.
I want to try this.
This on can suck. There are two possiblities that I am aware of that can cause this noise. One is the low coolant, if there is air in the heater core you may hear a gurgling sound. Most noticable when you rev the engine, even in idle. Second is the air box servo motors, this is what I need. You will hear a clicking type sound, and no matter what you do you can't change the sound. It may be constant or erratic. You'll need to get under the dash and inspect them to find out which one is noisey.
Good luck.
-Bill
Good luck.
-Bill
I brought the same noise attention to Lexus of Manhattan. Damn b#stards charge me labor to look at it and said it's "normal" because the car has auto-climate control so it does that funky noise.
My ex-IS300 didn't do that.
-Bill
I’ll check the antifreeze tomorrow…that one sounds far-fetched however. No offence to anyone.
The servo sounds more legit…but I ain’t taking the dash apart and the dealership will just be the same old song and dance.
I’m from Wisconsin and bow/deer hunting just opened, so I’ll crank Ted Nugent’s “Fred Bear” CD and the hell with the clicking noise. Stick-um and Grill-um!
Have a great weekend everyone!
Dakrri
Dakrri
MV4554
01-14-13 07:20 PM
