GS TSB's???????
GS TSB's???????
Could someone check this site and tell me if I could go to my dealership and demand for these to be fixed. 60 TSB's???? I dont take my GS to dealer for many services and do stuff outside.
http://www.alldata.com/TSB/31/98310710.html
I don't think this is a totally comprehensive listing since I don't see the tranny ecu upgrade I'm having done Thurs.
I'll still hunting for a totla listing, maybe one form Lexus....
http://www.alldata.com/TSB/31/01310916.html
Just wondering, how do you find out more about specific listing on the TSB?? like the paint -color codes??
PA004-00 NOV 00 Paint - Color Codes
So can I order for these to be done??
Bulletins for 1998 Lexus GS 400 V8-3969cc 4.0L DOHC MFI
Service Bulletins
TSB Number Issue Date TSB Title ST001-01 FEB 01 Steering Wheel Nut - Torque Standardization
AC001-01 JAN 01 A/C Indicators - Malfunction
PG017-99 DEC 00 Vehicle - Year 2000 Readiness Disclosure
EL008-99 DEC 00 Engine Immobilizer System - Precautions
SS003-00 DEC 00 Diagnostic Tester - Communication Error w/TIS
PG005-00 JUL 00 Service Manual - Page Corrections
AC001-00 JUL 00 A/C - Compressor Maintenance During Storage
EL003-00 APR 00 Distance Since Refueling Display - Inaccurate
NV005-00 APR 00 Center Seat Belt Retractor Cover - Rattle
ST002-00 APR 00 Steering Column - Slider Sub Assembly Available
PG001-00 APR 00 CA/50 State Certified Emission Control Label Ordering
AX001-00 MAR 00 Towing - Dinghy Towing (Four Wheels On the Ground)
NV001-00 JAN 00 Garage Door Opener - Rattle
NV003-00 JAN 00 Glove Box - Rattle Noise
BO005-99 DEC 99 Seat Belt Extender - Availability
BO004-99 DEC 99 Moonroof - Creak Noise Reduction
SU001-99 SEP 99 Wheel Balance - Adjustment Procedure
TC003-99 SEP 99 A/T - Fluid Recommendations
SS007-99 JUL 99 SST Program - Special Service Tools
SS006-99 JUN 99 Scantool Immobilizer - Key Code Utility
SS004-99 JUN 99 Wireless Recognition Codes - Alternate Register Method
EL005-99 JUN 99 Power Moon Roof - Motor
PA002-99 MAY 99 Paint - Refinish Formula Codes
PG010-99 MAY 99 Service - Manual Corrections
BO002-99 APR 99 Glove Box Switch - Rattle Noise
SS001-99 APR 99 Diagnostic Tester - Customize Program Card Update
TC001-99 APR 99 Drive Shaft - Grease Revision
AU001-99 APR 99 AM Radio - Crosstalk Interference
AX003-99 MAR 99 Dinghy Towing Guide - With Four Wheels on the Ground
EL002-99 MAR 99 Antitheft - Troubleshooting Immobilizer DTC B2795
EL003-99 MAR 99 Antitheft - Troubleshooting Immobilizer DTC B2796
PG002-99 FEB 99 Brakes - Publication Correction Information.
SS002-98 DEC 98 Tools - Installing Rivet Nuts
NV020-98 OCT 98 Glove Box Area - Squeak & Rattle Service Tips
NV018-98 OCT 98 Instrument Panel Area - Squeaks & Rattles
NV021-98 OCT 98 Interior - Squeaks/Rubbing Noise
NV019-98 OCT 98 Package Tray Trim Area - Squeaks & Rattles
AU003-98 OCT 98 Radio - Inoperative In CD Mode
BR002-98 SEP 98 Brakes - Hydraulic Pressure Switch R&R Corrections
AC003-98 SEP 98 A/C - Soluction to General Malfunctions
BO004-98 JUL 98 Seat Cover - Service For Side Airbag Equipped Vehicles
BO003-98 JUL 98 Seat Belt - Extenders are Available
SS001-98 JUN 98 Vehicle - Special Service Tools
TC003-98 JUN 98 A/T - Fluid, Type T-IV Introduction
ST003R-98 JUN 98 Steering - Vibration/Flutter
PG004-98 JUN 98 Service Manual - Publication Correction Information
BO002-98 APR 98 Door - Disassembly Precautions
BO001-98 APR 98 Seat Belt - Extenders Available
NV002-98 APR 98 Wind Noise Service Tips
EL005-98 APR 98 Cigarette Lighter - Service
EL006-98 APR 98 Tachometer - Incorrect Indication
EL004-98 APR 98 Wireless Door Lock Control - Programming
TC002-98 FEB 98 ECM - MIL ON, DTC P0715 Set
EL001-98 JAN 98 Engine Immobilizer - System Precautions
ST001-98 JAN 98 Progressive Power Steering (PPS) - Manual Corrections
EL002-97 DEC 97 Fuel Gauge - Incorrect Reading
PA00297 NOV 97 Paint - Colors
EG007-97 NOV 97 Serpentine Belt - Squealing Noise on Cold Start Up
SS002-97 OCT 97 Customize Program Card - Version 1.0 Update
BO007-97 OCT 97 Seat Belt - Extenders Availability
PG005-97 SEP 97 Fuse - Installation During PDS
PG006-97 JUL 97 License Plate - Installation During PDS
PG003-97 JUL 97 Certification Labels - Replacement Policy
PG002-97 MAR 97 Air Bag - Information Label On Glove Box Door
PG002-96 APR 96 Emission Control Label Order Form CA/50 State Certified
PG93-004 MAY 93 A/C - Ozone Depleting Substance Caution Labels
PG93-003 APR 93 Vin Plates/Certification Labels - Replacement
PGI004 SEP 91 Recycled Coolant - Usage Recommendations
BODY026 AUG 91 Body - Permanent Type Protective Wax Coatings
Service Bulletins
likely no - esp the ones before 98
You'll likely need to make a decent case for what you are wanting to have done, like describe the symptoms first, then mention you are aware of a TSB for it....
After all, these are not recalls; Lexus won't do the TSB for you unless you ask for it - they're not getting paid for thier labor....
What I think is unfair is lexus will only fix the TSB's if you still have your car under warranty. Its lexus's own little mistakes in design that TSB's are there in the first place and they should just honor the customers request and fix it with warranty or not.
I have just recently discussed doing some FAQs for our rides with mkilty (Admin), and he just pointed me in the direction of some of the newer developed FAQs in the newest generation of CL
https://www.clublexus.com/html/modul...us+Maintenance
A good basis for what we're already discussed here.
HTH
HTH
