well it has happened to me too. my passenger front and rear were wet. this is the first time i noticed it so im not sure where it might be coming from. it was clean water. so i just have no clue. Anyone got anymore ideas
Did you actually read the first post? or did you just scroll down and start typing?
yes i read the entire post and 3 other ones. i have tested drain holes. it is water not coolant. i checked drain pulgs on the bottom. my ac dripps on the ground like it is supposed to. im out of ideas.
thats the only thing i am coming up with now. maybe windshield seal too.i washed my car the other day and i used a pressure washer right where the vents under the windshield wipers are to get leaves out. do those vents run into my car?
I have the same problem. I checked the carpet on the drivers side and it was soaked. I pulled back the carpet and found the leak. The water is dropping where the red circle is on the picture and running down to the floor. My drain hose behind the firewall seems to have a steady flow of water, but I'm not sure if it's obstructed or not though. The dark stuff is some type of undercoating.
Dude the problem is your evaporator or condenser in short the Lexus Dealer charges $1900,just to get to the part out and plus the cost of the piece to replace,in short this fixed done right is around $3000.00 if not don't run your A/C or get creative with some JBL lube under plastic which is dripping good luck with that tight area trying to patch it up
well i figured it out today. the rubber boot my amp wiring and factory harness go threw on the passenger side firewall had a hole in it and was leaking threw into the floor board. man i was so happy it was that simple.
5.Moonroof Drain Clogged
+ Fill a cup of water and place it in the Moonroom Drain
+ It should flow out underneath behind the front tire.
+ Check if it is leaking in the car.
+ If it is use compressed air to blow the debri out of the drain.
+ Video: http://www.youtube.com/watch?v=5-JE2Isu0qs
Clogged moonroof drain seems to be the likely culprit. This is a common problem on Toyota vehicles. Last months 'Motor' magazine has an article with diagrams about this very problem and how to remedy it. I will see if I can get a snap shot of the article and post it up.
