Wet under drivers side mat.
Old 10-07-06 | 06:42 PM
cpone's Avatar
cpone
There can only be One
CL Folding 2M
Default Wet under drivers side mat.
I was cleaning out my car today.
And I pulled up the drivers side mat and saw that it was damp.
I tried lifting up the carpet but didnt want to rip it out.
I stuck my hand in there pretty far but it wasnt that damp back there at all.
Anyone have any idea what this could be?
What could be causing it?
The solution?
Has anyone ever even heard of this?
Old 10-07-06 | 07:46 PM
dusouth's Avatar
dusouth
i noticed the same thing in a couple of my cars, i think its condnsation from a/c blowing cold and the undercarriage being hot in the florida.
Old 10-07-06 | 09:49 PM
Tyke's Avatar
Tyke
Nope thats not that...its either ur condenser or evaporator that has gone bad. This thing is expensive. Have u been loosing antifreeze? If u have and dont knwo where it ahs been going, now u know. Take off moldings and remove carpet to see just how wet things are under the carpet...remember that theres alot of foam under the carpet which has been absorbing all that water, so for it to feel damp that means its pretty soaked.
I know theres a way to by pass this device by disconnecting some hoses and plugging them to each other but im not sure how to due it...only problem u wont have a heater but u will save $$$$$ large bills, cos i think u have to take off dash board....PITA.....this is ofcourse assuming is the same probelm i had in a SC400 I had
Old 10-07-06 | 09:59 PM
IGGYWOOWOO's Avatar
IGGYWOOWOO
Welcome to the club!
https://www.clublexus.com/forums/sho...ght=evaporator
Old 10-07-06 | 11:30 PM
dusouth's Avatar
dusouth
Talking
i don't know much about sc400 but if the evaporator was leaking wouldn't the passenger side be wet? he said the drivers side was wet. i used to own an 87 monte carlo with a leaky evap but it was always wet on passenger side.
Old 10-07-06 | 11:52 PM
Tyke's Avatar
Tyke
crap yes! My bad for not paying attention...evap problem will be on passenger side.....so if its n drivers side hmm weird...maybe it went from the passanger to driver???? dunno
Old 10-07-06 | 11:59 PM
Ishinc's Avatar
Ishinc
I had the same thing. It seems like a ton of people has or had this problem. I believe if its your evap then you will be leaking anti freeze. You can smell antifreeze for sure. If it just water, then you may have a clogged AC drain tube. Try unclogging the tube from under the car and see if that helps! You can try blowing air into the tube to maybe some wire? That was my problem, thank goodness it wasn't the evap.
Old 10-08-06 | 05:46 AM
BMwhat?'s Avatar
BMwhat?
holy crap!!! im not the only one with this problem???????? i just noticed mines was soaked when i was cleaning my carpet a few days ago.... i just dried it up the best i could and left a towel to soak up the rest of the water.... its dry now.... i guess i'll just wait if it gets wet again. then i'll know i have a real problem.
Old 10-08-06 | 05:56 AM
GWELEX's Avatar
GWELEX
Check for missing body plugs on the chassis. There's a thread with a pic which shows them. Apparently age takes it toll and these things will fall out. May not be your problem but it's something to else to eliminate.
Old 10-08-06 | 09:01 AM
cpone's Avatar
cpone
CL Folding 2M
ok this morning I drove without my mat..a/c on full blast 4 about 40 minutes and nothing. I was at my mothers house for a about an hour yester and she has a steep incline at her home. so I am thinking that maybe its a clogged tube like someone mentioned. causing water to back fill into the car. right now my car is sitting flat for about 3 hours and nothing so far. I am really hopping its not the evap.
Old 10-09-06 | 02:07 PM
RICHYRICH's Avatar
RICHYRICH
Ive had the same problem too..Took it to the dealer and they said I had a cracked evaporator case that cause water to leak there when it fills up ??? 1600$ is what they wanted to fix 2600 to replace the evaporator if that goes bad..told them i will wait till the evaporator goes out !!
Old 10-20-06 | 02:54 AM
dung0981's Avatar
dung0981
CL Folding 10,000
Did anyone find the problem?? I have the same issue... but when i checked it, it was not anti-freeze there... but that just some water? Do you guys think that would be the evaporator??
Help please...
Old 10-20-06 | 08:35 AM
LEXUS_KID's Avatar
LEXUS_KID
Did anyone check there body plugs as of yet
Old 10-20-06 | 06:40 PM
dung0981's Avatar
dung0981
CL Folding 10,000
I did but i still have this leak... anyone? It's fresh water. Do you guys think it is water condensate from the A/C system?
Thanks
Old 08-11-07 | 05:14 PM
TriniLex's Avatar
TriniLex
Default Wet Carpet Here are the Solutions
Carpet wet?
First you must isolate where the water is coming from. Pull back the carpet.
Is it only Passenger side, Driver side, Roof?
Problems:
1. The rubber molding is not seated correctly
+ Check the rubber around the door as well as around the door jams
2. Evaporator is leaking (A/C)
+ Could be costly (about $650 from a regular mechanic)
+ Most likely only the passenger side will be wet
+ AC will be blowing warm
+ Distinct smell from the liquid leaking out
3. Hose Leaving Evaporator box is leaking into the car or is clogged
+When you look in the engine bay you will see a black rubber hose coming out from the fire wall. This is where you can have a clog.
4. Rubber Gromets under the carpet is missing or leaking
+ When you remove the carpet you will see the 2 black rubber gromets.
+ Check to make sure they are snug in place, if not place some silicon around it.
+ Sometimes the gromet drops out (can also cause a whistling noise when you accelerate)
5.Moonroof Drain Clogged
+ Fill a cup of water and place it in the Moonroom Drain
+ It should flow out underneath behind the front tire.
+ Check if it is leaking in the car.
+ If it is use compressed air to blow the debri out of the drain.
+ Video: http://www.youtube.com/watch?v=5-JE2Isu0qs
