Bypass amp or use it?
I am planning my install of my Double-din Navi unti. I love the sound as it is now. Nak Headunit- Pioneer cd changer and Kicker free air sub. Can I keep the exact same set up and have the factory amp with my Navi unit or will I have to add am aftermarket amp to acheive the same audio quality as before with the factory audio? I have searched for a few hours but have not received a definitive answer. I know someone here has that final yes or no. Thanks for the help in advance.
Thanks...
Not sure about the model number of Kicker but yes it is powered by stock amp. The unit is a jensen so for the plug and play I believe it is a no go. My question was will the sound be better or worse after I change the headunit without the stock amp. If better then cool but if worse is there some way to get the amp to work with the new headunit?
When I initially installed my AVIC-D1 we tried to power up the stock amp.
It has two turn on switches and we could not get the amp to stay powered up- apparently the turn-on leads flip-flop somehow.
We abandoned the factory amp. The OE Nak speakers sounded okay, but I had no sub. I could not find any harnesses that were plug-and-play with the Nak head unit.
hey
Originally Posted by socal
Socal did you try to hard wire the sub to the radio directly? I am dreading this situation because the sub is what I need the most.
ArmyofOne
04-26-19 04:41 AM
ArmyofOne
12
11-03-04 12:09 AM
