Removing stock exhaust tips
Yes I've searched, and yes I know that the stock exhaust tips are not welded, but rather, are crimped onto the exhaust pipes. Does anyone have first-hand experience with removing them? I've been working on one side for the last 1/2 hour and I can't get the thing to budge. I can see the inner sleeve that's holding it in place, and I've tried to pry it away from the exhaust pipe, but I'm not having any luck. Does anyone have any tips? Thanks in advance.
e
e
hit it with a rubber mallet from the back. and use a screw driver to pry open those tabs. If all else fails, grab it and pull it while turning them left and right. Careful not to cut yourself.
Thanks for the "tip." I don't have a rubber mallet, but I'll try to borrow one. I probably should have mentioned that the mufflers are off the car. Does that change anything? It's kind of hard to get any leverage.
I did mine while on the car, and I shook the car a bit while jiggling them, lots of force. Holding the exhaust in place will be your biggest challenge.
WD-40 will help a lot when removing the tips.
what are you trying to do? Will the tips need to be removed? if so, try not to hit too hard or dont hit it at all.. it will start to bend.
Best way would be to just try to pry it where the tabs are. Spray some wd40 and just pull and twist while you are prying it.
I'm putting new tips on, so I really don't care if I destroy the old ones in the process (although I'd rather not). I just want to make sure that I don't damage the pipes.
With the mufflers off the car, I have no leverage to pull. I've pryed the inner sleeve as much as I can, so maybe I'll try some WD-40 and a rubber mallet. I'm just concerned that I'm not doing it right because these things haven't budged an inch.
Good luck!
Actually, I do have a Dremel with a cutting wheel, but I'm not all that skilled with it. I don't think I'd be able to cut through the tip without doing some serious damage (most likely to myself).
Well, if you dont care that the tips get destroyed, you could try cutting a strip longways on the tip and then peeling the tip open. That should let it go of the exhaust pipe.
