Car won't start...possible fuel pump or starter problem? Please help!
Hey guys, my 98 GS400 won't start. All electricals, including headlights and horn work. The engine is not flooded, holding the gas while cranking doesn't help. I tried both keys thinking the immobilizer chip in one may be damaged, didn't work. The engine doesn't even turn over, you just hear like the starter. I think the problem is either with the starter or possibly fuel pump...has anyone had this problem or know what it is? Is there any diagnostic test I can run myself to check? Any help would be appreciated.
Thanks!
Thanks!
- Try getting a jump start and you'll know it's the battery if you get started.
If you hear one click then silence...then it's possibly a failing starter.
- Once this problem starts occuring you may notice times when the car will start and other times it won't..it all depends on temperature and other condition such as how degraded the starter has gotten. You can keep trying to click the starter and eventually you may get going...I could do this for a few months before my starter finally had it and I got it replaced.
- Members have rebuilt their starter for not much $$...dealer replacment will cost you around $1200 big ones...mostly labor charge.
one way to check if your fuel pump has gone down south for the winter is... turn your key to the on position and you should be able to hear the fuel pump/sending unit doing its job. if you dont hear anything then that might be the problem. this is how i checked it on my 96 Impala, it should be the same on all cars but im not sure... doesnt hurt to try though!
There is a buzzing/humming sound when you turn the key to the on position, I always get that sound, I remember hearing that it was brake fluid being pressurized or something like that. I'll try it again though and listen for anything, thanks!
If you hear the anoying rapid clicking sound from the engine bay but no engine cranking....then it's very possibly a low battery charge.
it took me all of 1hour and a half to take the starter out(3bolts)...and to rebuild it, and put it back in... works like a charm... very simple ..if you have someone with a lift... you wont have any problems... if its the starter that is ...
after 8 years the copper plates in the starter end up disolving under the pressure of constant turns of a key
I boosted the car a few days ago and it has been running fine since, but I'm worried that the alternator or battery might be bad because I can't figure out why the battery lost charge in the first place. Anyways I guess I'll wait and see if it dies again....thanks for all the help!
Serpentine belt is loose causing alternator not to generate enough power to charge your battery, few days is just enough to run battery down so you won't be able start engine,
That would be my guess....
