I broke a lug off my front hub...dayum!
Guys go invest in a torque wrench. It's only about $25-30 for the click type at autozone, oreilys, or even walmart. I used to hand tighten the bolts with a breaker bar as well...good thing nothing bad happened to me during that time. A cheap torque wrench is ok if you only use it "occasionally" since most of them are light duty. It will give you peace of mind that everything is at the right tightness/spec
Hey thanks for jumping on this gents. I feel better now. I guess I was applying to much pressure. I am only 165 lbs and thought I was applying less the half my weight in pressure. LOL...but yes I was using a 2 foot long breaker bar over the ratchet giving it even more torque than I am accounting for. I did not know you could replace the lugs individually....phew!!
Time to invest in a torque-wrench and....don't rotate my tires after returning from the gym!!
Thanks again,
Gerard
Thanks again,
Gerard
In the future, if this happens to anyone else, All u gotta do is beat out the stud with a hammer. Take it to the autopart's store, and have them match it up. Turn the position of the hub (place where the other bolts are at) so u can slip the stud in from behind. Next put on one nut on the oposite side of the new stud and thread it tight. Now put the nut on the new stud and tighten it down, Be sure to get it tight enough to get it flush with other studs. Take bolth nuts off, slip on the tire, tighten everything up and go peal out or something. Each stud costs no more than $3.00. Total work time for actual labor is 10min.
I got a tire rack torque wrench for about $30 and it's works nice. and yeah, 76lbs doesn't feel like much when you have a 20 inch long wrench.
http://www.tirerack.com/accessories/tools/tw605.jsp
http://www.tirerack.com/accessories/tools/pw1.jsp
http://www.tirerack.com/accessories/tools/sockets.jsp
I've changed out the studs on a gs4 before and its not difficult at all. Took about 30 mins and simple hand tools.
If anyone is interested in doing it themselves, I could do a small write up, no pictures though.
The front ones are super easy. Its the studs in the rear that I'd actually take to a shop to do.
Thanks again for the help~
G
