gs300 or gs400? help!!!!
ok..my question is..will i be happy with a gs300? or will i regert not gettin the v8? becuase im searchin for one..n i found a white 2000 gs300 w/ 82,000 miles going for about $10,500. and i found a black 2000 gs400 w/ 78,000 miles going for $16,000..i dont know about u guys but 5,500 is alot of money..but..is it worth it? for the gs400? wht u guys think..feedback please!!!
So many have had regrets after purchasing a GS300. Not many will turbo it though the dreams of doing so convinces them to get one over a GS400. So few actually go through with it. Plus the fact that a 400 badge carries a bit more stature for some than a 300 badge. Both great cars. A clean GS400 with around 90k miles can be had for 10K nowadays if you are patient. A white GS400 sold at a local car lot that appeared pretty clean with clean title with 97k miles for $9999 and some change. Good deals are out there for those that can wait. Otherwise 11-13k for a 98 would be about right.
GS4...all the way!
CEO
CEO
just bought a 98 GS4 (with help from my boy SoCal VIP - thanks, bro!). it's definitely got some giddyup. he knows a thing or two about Lex and advised the V8 all the way. black on black with 64K miles for $14,5. pretty sweet. ;-)
Hi group. I'm a current LS430 owner and currently looking for a 2GS for my wife as her daily driver and once in a while mine, when the LS430 is staying in the garage. I doubt that I will be going the turbo way if I do decide to go with a GS300 but considering gas prices, driveability, realibility, is the GS400 the way to go?
I am planning on minor mods (suspension, wheels, exhaust) if that matters. Thanks in advance.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
Here you go... search works great here in the GS forum
, welcome to CL ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Should I get a GS300 or GS400? (found by searching with "which gs300 gs400" in the GS forum)
Sample Related threads:
https://www.clublexus.com/forums/sho...ch+gs300+gs400
GS300 or GS430
https://www.clublexus.com/forums/sho...ch+gs300+gs430
Typical GS problems you should be aware of (most consider these minor)
Moisture in Healights
Low/rough Idle Issue
Door Actuator Problems
Dash Rattle
Sunroof Rattle
Vibration at Highway Speed
https://www.clublexus.com/forums/sho...400+Rough+Idle
https://www.clublexus.com/forums/sho...=Door+Actuator
https://www.clublexus.com/forums/sho...ht=Dash+Rattle
https://www.clublexus.com/forums/sho...Sunroof+Rattle
https://www.clublexus.com/forums/sho...GS400+low+idle
https://www.clublexus.com/forums/sho...light+Moisture
https://www.clublexus.com/forums/sho...s400+Vibration
and will cost you $7-10K more PLUS leave you broken down or in the shop a whole lot more often
Some may find this the best option, but IMO for 95 percent + a reliable daily driver with some power is perfect.
GS300 or GS430
Dash Rattle
Sunroof Rattle
