Ever wanted to do a retrofit yourself? Here's how!
Old 11-21-06, 12:34 PM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
Originally Posted by chinkster
yeah i'm talking about 98-00 tail lights. so you do bake and separate then right?
Yes you can bake and separate. Do a search on this topic. There are numerous threads. I think this is getting off topic from this original post, so PM me if you have more Q's.
Old 11-21-06, 05:37 PM
JeffTsai
JeffTsai's Avatar
Thanks for all the positive comments. I was hoping you guys would like a good writeup on retrofitting the GS headlights. I'm going to post up more retrofit DIY's soon using different projectors.
damn thats a clean *** job bro. i actually read all the steps too . one thing tho, when you resealed the headlights did you apply some more glue or did you just heat up the existing glue again and clamped the headlights together? for a clean job.
Nope, just reused the original glue. Heat it up first and push all the glue back into the seams. This will create a nice watertight seal. You can add additional sealant if you want, but it's not really necessary.
Originally Posted by GSteg
dude..we have the same charger to test out the ballast/bulbs before I had that, I use to run back and forth to my car so I can see what they look like when lit up. lol.
I gotta agree with you though. First time retrofit stinks, and you only get better at it. My TSX retro was okay, but meh..not something I was happy with..Then came the LS430 projectors and the rest was history
Yeah, retrofitting is an art and skill. You just gotta keep doing it over and over...eventually you get better. How's are the LS430 projectors on your car? I love the wide beam output and cutoff on those
Originally Posted by I.B.dAt.Fo
excellent write up!! what are the black and orange wires sticking out on page 3?? and can you do a write up on how you made your relay wiring harness?? thanx
The two wires are for the Bi-xenon solenoid. Basically a motor that pulls down the shield so the low beam turns into a high beam projector. The two wires are hooked up to the high beam connector. As for the relay harness, I'll post up a DIY whenever I make another set.
Old 11-21-06, 06:33 PM
Adam2562
Adam2562's Avatar
i'm actually in the process of putting RX330 HIDs in my yellow fog housings..
Old 11-21-06, 08:10 PM
LEXUS_KID
LEXUS_KID's Avatar
Great write up
Old 11-21-06, 09:08 PM
VM 2
VM 2's Avatar
so what color did you end up with for your ambient lighting? i was thinking orangy yellow?
Old 11-21-06, 10:20 PM
Adam2562
Adam2562's Avatar
VM 2 -- who are you asking?
Old 11-21-06, 10:26 PM
JeffTsai
JeffTsai's Avatar
I think he's referring to one of the DIY's on my page. The one on: How to install ambient lighting. It was actually cliffud that did that writeup. I just added it to my site.
Old 11-21-06, 10:29 PM
Adam2562
Adam2562's Avatar
o ok gotcha.... you should check out putting HID's into the yellow housing fogs.. it looks amazing.. i only have one side done.. so i'll take a pic of them on tmrw to show the difference...
Old 11-21-06, 10:44 PM
JeffTsai
JeffTsai's Avatar
Adam2562, You can delete your own post. Just hit the edit button and there's an option to delete the post.
As for the HID in fogs, yeah I did that. I went the lazy route and just put a HID kit in there. I'll eventually get around to retrofitting a HID projector in there as well. For your setup, are you retrofitting a set of RX330 projectors into the fog? Only reason I ask is because I dont think the RX projectors will fit. They're pretty tall and they probably wont fit unless you make bulges in the fog housing. I believe they're 2.5" lenses.
Instead, I would recommend the 350Z pre-06 projectors because They're the smallest projectors avaiable on the market. I believe the lens is 1" on those.
Old 11-22-06, 05:25 AM
brit_lex
brit_lex's Avatar
great write up, you da man..
my question is, what took longer, the retrofit or the writeup of the retrofit? that's a lot of pictures!
Old 11-22-06, 06:18 AM
cxp2001
cxp2001's Avatar
Great write-up Thanks for sharing..
Old 11-22-06, 08:06 PM
DarKnight
DarKnight's Avatar
This needs to be made a sticky.
Old 11-22-06, 08:41 PM
will33184
will33184's Avatar
nice page jeff!
Old 11-23-06, 03:51 PM
BIGMerle
BIGMerle's Avatar
GREAT WRITE-UP!!! just wish i had the time to do a set myself
Old 11-23-06, 04:10 PM
Ay-nako
Stop the Copy!
Ay-nako's Avatar
wow that was awsome, to be honest ive got a 2 sets of headlights in my garage... i already know what ill be tryin to do
Quick Reply: Ever wanted to do a retrofit yourself? Here's how!
