cracking/twisting noise in interior
Is there any one here that has access to a fax machine and a scanner?
This person may be so kind to volunteer to have the document faxed over to you, scanned and posted for all club lexus members to benefit.
Thanks!
Manuel
Thanks!
Manuel
I can scan and re-post as a jpg or pdf.
925-xxx-xxxxis the fax.
Ron, if you're using a Brother brand machine, send it on SuperFine instead of Fine.
Here's the Doc!
Thanks to duster for passing this along!
The doc is a scan of a fax of a fax, and the best rez is in a PDF, which I can't attach here (jpg was too big and lowsy rez).
Click Here to open the PDF in a seperate window using Acrobat Reader. Right click and you can save to your hard drive.
