Daytime running light?
Are there any bulbs out there that i could use for my daytime running light so at night they won't look yellow? Instead I want them looking more white!
The bulbs running at night are not daytime running bulbs. They are your parking lights. The daytime running lights are simply your high beams at 50% output. They do not run at night when your headlights are on. You want to replace your parking lights which is the wedge bulb on the bottom of the same housing as the high beams. Any 194 bulb will work.
Try Going to Car-Gym.com. There located in Hong Kong. I bought the Piaa Tera LED 6000k & 6500k. They Look great. They are whiter and brighter then the stock Bi-xeon's.
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
I put in an ebay, Nokya 9005 bulb in there and it's night and day difference. Not bad for some cheap bulbs but my only gripe is, when they'e not on, you could see the blue reflection of the bulb throughout the housing.
i could sacrifice some blue gayness whilst the car is off for some non-yellow DRL's!
