Can you say, "YOU ARE TOAST!"
I just had to post this up for you guys to see! This ************* car is the ******!!! :eek: :eek: :eek:
Specifications
Year 2002 Powertrain Layout Mid Engine / 4WD
Make Bugatti Base Price est $800 000 USD
Model 16/4 Veyron Production Not Available
Engine & Transmission Body / Chassis
Configuration Quad Turbo W16 Weight Not Available
Valvetrain DOHC 4 Valves / Cyl w/VVT Length 4466 mm / 175.8 in
Displacement 7993 cc / 487.8 cu in Width 1998 mm / 78.7 in
Power 746.5 kw / 1001.1 bhp @ 6000 rpm Height 1206 mm / 47.5 in
Torque 1250 nm / 922.0 ft lbs @ 2200-5500 rpm Wheelbase 2700 mm / 106.3 in
Bhp / Liter 125.25 bhp Front Track F 1723 mm / 67.8 in
Bore 86 mm / 3.39 in Rear Track R 1632 mm / 64.3 in
Stroke 86 mm / 3.39 in Steering Not Available
Redline Not Available Body / Frame Not Available
Gear Type 7-Speed Front Brakes Not Available
1st Gear Ratio Not Available Front Brake Size Not Available
2nd Gear Ratio Not Available Rear Brakes Not Available
3rd Gear Ratio Not Available Rear Brake Size Not Available
4th Gear Ratio Not Available Front Wheels F 52 x 23.5 cm / 20.5 x 9.3 in
5th Gear Ratio Not Available Rear Wheels R 54 x 32.5 cm / 21.3 x 12.8 in
6th Gear Ratio Not Available Front Tires PAX 245/690R520
Final Drive Ratio Not Available Rear Tires PAX335/710R540
Performance
Top Speed 406 kph / 252.3 mph 0 - 60 mph est 3.0 seconds
Specifications
Performance
Originally posted by fairuza11
DAYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYAAAAAMMMMMMMMMMMMM!!!!!!
Take a look at the engine compartment!!! Oh by the way, it's sitting behind Your Head!!! :eek: :eek: :eek:
Still pretty sweet!
But I can do without the UGLY grill....did you say $800,000.00 USD....errr looks like they found that grill in a junk yard.
The rear end is nice...very tough looking....I guess with that huge engine (487.8 cu in ) back there its got to be tough.
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
Originally posted by wantAnewLex
Volks Wagen can take that thing and SHOVE IT!!!!!!
Originally posted by Richie
I like it but I would never be able to afford it :-(.
