Replaced the starter on my '99 gs300
Could you repost the pictures. I need to replace my starter. I have replaced on on a Suburban before and if memory serves correctly the hardest part was propping it up to screw it in while bearing the weight. Is it a tight fit?
Any help would be appreciated. Thanks.
I just finished installng mine. I didnt need to take the tranny out, I did have to use extension and a universal to manueaver to get to the long bolts holding in the starter, it worked and I'm back on the road. I got the autozone duralast for $159.99 w/lifetime warranty. Good luck!
Good luck
Sewell's sells the starter contacts or brushes for starter and alternator. Not hard to replace these at only around $20. The contacts wear down over use and that is the culprit 95% of the time.
Cyclenby
SC- 1st Gen (1992-2000)
08-14-10 09:18 AM
