Greddy Front Lip & Roof Spoiler Installation Process HELP!!
I gave my lip to my repair man at the shop and he needed to know how does the lip fit on there, does it just stick on with adhesive or bolt on?? Also how does the roof spoiler go on the rear windsheild?? It would be helpful if i could get some posts with pics if possilbe. Car is at the shop now and results would be appreciated.
Thanks guys
Thanks guys
The GReddy lip simply wraps around the lower front bumper. The center of the lip has inserts that will hold the slits of the front bumper, and then you will need to screw in the lip on the sides, inside the front wheel well. I told the bodyshop to use better nuts and bolts rather than the small and weak screws that came with the lip.
Every different roof spoiler has its own installation methods. Some are attached to the edge of the roof, while others are attached on the top of the rear glass. But most of them are held in place by tape or other adhesive. Just use some strong 3M tape and stick it on.
Hope this helps.
Hope this helps.
chuckdaddy
10-29-10 12:45 PM
