I was trying to connect the wires for the bi-xenon projectors. On the highbeam which wire is negative and which wire is positive? One wire is red the other is white with a red stripe.
Wait, I thought you have the Bosch Bi-xenon projectors? That's a 3 wire motor and needs a different way to trigger the bi-xenon solenoid. As for the wires, mine are both black but one has a green stripe. The one with the stripe is the positive. I'm not sure about yours though. Best way to make sure is to use a multimeter.
Jeff I'm talking about the wires that are on the car. One is red and the other is white with a red stripe. The ones on the projectors are green, black and red.
Well I found out that I didn't mess up my electrical system I just burned a fuse, thank God. But now I just need to know on the car which wire is positive and which wire is negative.
