Info on a nice GS drop
hmm...well there is cambering, but not any tire wear issues, i had my 19's on this past summer and they wore pretty even across the tread. Usually excessive inside tire wear is caused by too much toe out. If you ever noticed there are vehicles that are stock with noticeable negative camber on the rear wheels and I would think that the manufacturers would not engineer their vehicles to produce excess tire wear because of consumer complaints...well theres my two cent.
I believe the most conservative drop is Eibach prokit (1" drop compared to 1.25" drop of L-tuned). After maxing out the camber adjustment during alignment, my car now has close to zero negative camber. Please note that our car actually came with negative camber (for better handling), therefore having zero camber is just not possible once you lowerred it. Right now, the camber reading of my car is very close to zero, which is out of spec, to give me the max longevity of the tires. I think going with 1" - 1.25" drop will allow you to keep the camber reading with in spec.
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
Hey fellow members, I have STOCK suspension and 20" rims but my front tires are worn severely on the inboard portion and pretty much new 3/4-outboard portion. Is it something that can be corrected with an alignment or am I S-O-O-L?
Hope that helps.
Hope that helps.
Please enlighten me, I don't want to put new tires until I educate myself on this
I've heard good things about the Espelir ASD's. They drop a good amount and still keep a stock-ish ride quality.
Now does anyone know if these springs will give more camber wear than, say, the Tanabe DF120 or NF210's?
Hope that helps.
Hope that helps.
took my tires off after 6 months with the Espelirs and no inside tire wear with 18's. This pic has the winters on... back is sittin low, with 2 - 75 lb sandbags for winter.
hey how about someone fill in the blanks
You should get __(insert springs here)__ for a __(insert inches here)__ drop. This will ___(insert what he'd like to happen)__ and make sure that ___(insert what he doesn't want to happen)___ won't be a problem.
Oh and one more thing, ____(insert any additional info)____.
I don't think Eibach and L-tuned are the same spring. There's a thread somewhere that talks about this. A member actually did a study in size and weight between the 2 spring to draw this conclusion. That's not to say that the L-tuned spring is not made by Eibach. It could very well be (per Lexus spec). As it stands, I believe those are different spring (not by much but not the same). The Eibach spring should give a 1" drop vs. 1.25" of the L-tuned. I also think that the Eibach spring is a little stiffer (not by much).
On camber issue, as I previously stated, our car came with negative camber. However, you can adjust the camber a little while doing alignment. There's no camber kit available, you're pretty stuck with a little adjustment that built in to the car. But you can adjust it. Knowing that going in, I asked my mechanic to max out my camber before finishing alignment. Right now I have close to 0 degree front and back. The spec requires some thing like -.1 to -.3 for the rear (I don't remember the front). Which means, I'm out of spec. However, this should give me the max tire life.
I decided to change springs and dampers at the same time to save me the hassle of redoing it in the future. As far as damper goes, Bilstein sport was my first choice. After talking to the Bilstein rep on the phone, I learned that they do a lot of testing with Eibach spring. Therefore, I thought that Eibach and Bilstein would make a nice combo.
In the end, I'm very happy with my current set up. Running on stock 17", I think this set up the an improvement over stock ride quality and handling.
