Info on a nice GS drop
Old 02-07-07, 07:14 PM
  #31
bugeyeGS
bugeyeGS's Avatar
Originally Posted by MORE4MY 4
Hey hope this can help u this is my 98 GS 400 on daizen springs .
damn looks great online but even better in person
Old 02-07-07, 07:46 PM
  #32
ReLexin
ReLexin's Avatar
will someone clarify if this is a true statement?????!!!! thanks
Originally Posted by blue99GS4
I don't think Eibach and L-tuned are the same spring. There's a thread somewhere that talks about this. A member actually did a study in size and weight between the 2 spring to draw this conclusion. That's not to say that the L-tuned spring is not made by Eibach. It could very well be (per Lexus spec). As it stands, I believe those are different spring (not by much but not the same). The Eibach spring should give a 1" drop vs. 1.25" of the L-tuned. I also think that the Eibach spring is a little stiffer (not by much).
On camber issue, as I previously stated, our car came with negative camber. However, you can adjust the camber a little while doing alignment. There's no camber kit available, you're pretty stuck with a little adjustment that built in to the car. But you can adjust it. Knowing that going in, I asked my mechanic to max out my camber before finishing alignment. Right now I have close to 0 degree front and back. The spec requires some thing like -.1 to -.3 for the rear (I don't remember the front). Which means, I'm out of spec. However, this should give me the max tire life.
I decided to change springs and dampers at the same time to save me the hassle of redoing it in the future. As far as damper goes, Bilstein sport was my first choice. After talking to the Bilstein rep on the phone, I learned that they do a lot of testing with Eibach spring. Therefore, I thought that Eibach and Bilstein would make a nice combo.
In the end, I'm very happy with my current set up. Running on stock 17", I think this set up the an improvement over stock ride quality and handling.
Old 03-01-07, 05:38 PM
  #33
Bigbea
Bigbea's Avatar
Originally Posted by sockfocks
correction: the nf210 drops are 1.5 front and 1.0 rear, rides real good and no rubbing issues that i know of.
rear is sitting a little low, had some heavy equipment in the trunk...
I like the way that your car is sitting. Very nice. Not too low. I'm getting my 20's next week and I think that these are the ones I'm going for.
Old 03-01-07, 06:02 PM
  #34
4ntvings
4ntvings's Avatar
i think eibach and l-tuned are good for 20's (those springs are more conservative). to sit on 19's, maybe a set of espelir or daizens might be the better bet. of course, if you have the money, just get coilovers . i've heard very good things about daizen and espelirs all around, so i might go that route.
Old 03-01-07, 08:37 PM
  #35
Bigbea
Bigbea's Avatar
I just don't want to rub at all. I've heard soo many different responces about how low will not rub. People say you can get away with 1.5 with 20's.
Didn't mean to hijack....
Old 03-02-07, 12:18 AM
  #36
InspiredGS
InspiredGS's Avatar
hope this helps.. i'm running daizen springs/l-tuned shocks on 20s
Old 03-02-07, 12:40 PM
  #37
Bigbea
Bigbea's Avatar
do you rub at all? what size are your tires?
Old 03-04-07, 04:46 PM
  #38
Emackny
Emackny's Avatar
Thats that NY sh.. right there. Front window tinted.. lol. Gangsta'
Old 03-04-07, 07:09 PM
  #39
L3XOTIC
L3XOTIC's Avatar
honestly ill go with Tien CS just so you can adjust it at your convenience. Springs are springs, you cant lower or raise it once its on. So good luck.
Old 03-04-07, 08:19 PM
  #40
rodneyk
rodneyk's Avatar
From my own experience, regardless of drop, unless you have INSANE camber, several degrees of negative shouldn't give you too much premature tire wear if you get a proper alignment and set the toe-in to zero.
Make sure you get an alignment after you get a drop, it ends up paying for itself! And don't forget to post pics when you get it done
Old 03-04-07, 09:40 PM
  #41
IGGYWOOWOO
IGGYWOOWOO's Avatar
Why are the Tein springs never mentioned here? Especially the "H" springs? These seem like they would be perfect for a slight drop.
Old 03-06-07, 02:23 AM
  #42
1wickedgs
1wickedgs's Avatar
I went with coilovers.... can go lower and love the ride !
Old 03-06-07, 02:04 PM
  #43
blue99GS4
blue99GS4's Avatar
Default Eibach / Bilstein Combo
Here's my set up. Pretty conservative. 10K later, tires show no inner wear.
Old 03-08-07, 09:45 AM
  #44
rodneyk
rodneyk's Avatar
Eibach Prokit?
edit: nevermind, just noticed the post title haha, nice car!
djpolak
Suspension and Brakes
30
08-03-09 02:26 PM
Red Bully
27
11-16-08 05:53 PM
BIG TY
08-15-06 08:23 PM
blkvader
04-05-06 09:49 AM
GS400kid
03-17-03 05:07 PM
Quick Reply: Info on a nice GS drop
