turning off lights with remote
i have a problem lately where the lights won't turn off on the second click of the lock button on the remote. i *think* this started happening when the driver's door acutuator went bad. but i've replaced this and it appears to be working fine. any ideas?
got it...looks like when i took off the rear door panels to change the speakers a few weeks ago one of the door actuator cables got unhooked. thankfully it's not broken, hooked it back up and the remote turns off the lights now.
there is a lot of info, you should do a search. the stock speakers are 4", if you want to put in bigger you'll need to make custom mounting plates. no point really if you're using the stock system.
jmarr
ES - 5th Gen (2007-2012)
01-08-12 12:32 PM
nukeboy171
GX - 1st Gen (2003-2009)
03-28-09 10:19 PM
