Unable to input some options when programming Nav system. Screens freeze and touching screen to activate menu items is not productive. If I turn ignition key off and restart I can sometimes get farther into the menu. For example, if I want to enter a specific destination, I can sometimes get into the process of entering an address, but then the screen freezes. What's going on? Would disconnecting the negative side of the battery for a few minutes reset the system?
go to menu, system options
touch the top left, bottom left, top left, bottom left, and bottom right.
blue screen pops up and you select the top right option - override something..
select back and you're good to go
this does not work on the 98-00 hard drive based navi, there is no over ride that anyone knows of to input directions while moving. You have to input them while you're at a stop.
