New magnaflow pics
Old 02-01-07, 05:37 PM
  #31
GSoup
GSoup's Avatar
Originally Posted by isaacly
i bought these today.. 191 w/ shipping.. so are these a simple install.. just hang or is there welding and cutting involved? anyone recommend an muffler shop in so cal, thanks.
Its not a bolt on. You do need a muffler shop to do the work. It has to be welded.
Old 02-01-07, 07:01 PM
  #32
El Captain
El Captain's Avatar
I could not find the part number #14829 in three inch! I want this exhaust for my first gen GS300 with a 1jzgte swap! would this exhaust still be a good choice for me?
Old 02-01-07, 07:14 PM
  #33
chuckb
chuckb's Avatar
so what's the difference between the $180 ones and the $250?????
Old 02-01-07, 08:02 PM
  #34
owali
owali's Avatar
Do these mufflers have any drone at highway cruise speeds ~70-80 mph??
Old 02-02-07, 05:43 AM
  #35
DASHOCKER
DASHOCKER's Avatar
Originally Posted by Hameed
I sure hope I didn't waste my money buying the ones I did and should have just bought the same ones you bought that had tips on already.......
Hey Hameed..If you are having the pipes mandrel bent, it will be impossible to have the #14829 muffler tips dead center because it will require a very sharp bend in the piping almost 90 degrees. This sort of bending is impossible with a mandrel bending machine (which my muffler guy has). If you have the piping crimped, then you can have the #14829 mufflers on center for sure. I don't know if you are **** about piping, but I wanted the least amount of bends for maximum flow , thus the off center install. My install does are uniform as my guy was using a tape measure to make sure both sides were similar. Here is a pic of my magnaflows installed at the shop
and pic from last year
https://www.clublexus.com/gallery/da.../P10100061.JPG
The model number that you and lexmenow ordered will be right on center with the least amount of bends since it is has the same offset as the stock mufflers.. Read this thread by Alex(Azdesert)
https://www.clublexus.com/forums/sho...NAFLOW+INSTALL
Old 02-02-07, 06:54 AM
  #36
GSoup
GSoup's Avatar
14829 doesn't come in 3" piping. You have to get #14835. Its the exact same one but its 3" piping.
http://www.hottexhaust.com/detail.asp?product_id=14835
I purchased this one because it will work better with force induction.
Chuckb...The difference between the two is that 14829 has the piping center to center and the tip is already attached and the other one is off center to off center and the tip needs to be attached.
Old 02-02-07, 07:38 AM
  #37
Hameed
EV ftw!!!
Hameed's Avatar
Thanks for the clarification DASHOCKER!
Just like you I am **** about smooth exhaust flow and would only do mandrel bends, so I am glad I got the right ones so that the tips will be centered!
Incidentally, I called up John (owner of HottExhaust) and he said the 14289 is more suited to a 100 Hp Civic as the canister is smaller than the one I got which is more suitable for a 300 HP car. Not sure if was just trying to convince me that I bought the right muffler or if in fact the 14289 is meant for a lower hp car.
His reasoning is that the muffler (the canister) is smaller than the one I got and is also restrictive compared to it. Go figure.
Mine are coming in today! I didn't know that this company (hottexhaust) is local to me here in Canada!
Old 02-02-07, 07:50 AM
  #38
DASHOCKER
DASHOCKER's Avatar
LOL... at John's sales pitch. The 14829 canister is the same size. It is not small by any means..Heck it sure sounds throaty for a Civic exhaust lol.. The 14829 and any other model magnaflow muffler is considerably lighter than stock.
Old 02-02-07, 08:28 AM
  #39
GSoup
GSoup's Avatar
So because this muffler is smaller its more restrictive
Old 02-02-07, 11:09 AM
  #40
El Captain
El Captain's Avatar
You guys got me all messed up Will some one tell me wich exhaust to get for my first gen turbo!
Old 02-02-07, 03:36 PM
  #41
lexmenow
lexmenow's Avatar
No drone. Quiet as stock.
Old 02-02-07, 07:17 PM
  #42
isaacly
isaacly's Avatar
do u recommend a shop in socal? is there a lot of work? wondering..
Old 02-02-07, 10:57 PM
  #43
GSoup
GSoup's Avatar
turbo application i would go 3" piping.
I'm not familiar with the 1st gen if its off center-off center, but there isn't 3" muffler thats stainless steel if it is. The 3" one I went with is center to center. That's 14835.
I'm in NYC so I can't help you with that, but its not alot of work depending if your redoing all your piping from the headers back or your just cutting the existing piping and having them weld it to that.
I had mine done like the OEM. It had the flange put on it so it could be bolted on and removed just like OEM.
Old 02-03-07, 04:53 PM
  #44
El Captain
El Captain's Avatar
a dual 3 inch is like have a SIX inch muff dual 2.5" will work perfect!
ModInJapan
CL Vendor Products for IS-F
33
09-03-20 05:21 PM
EdsISF1021
05-09-18 07:55 PM
GS42NV
06-12-06 09:30 PM
lexus4jess
GS - 1st Gen (1993-1997)
05-05-05 09:32 AM
Seize
08-20-03 10:37 AM
Quick Reply: New magnaflow pics
