Code P0110
Code P0110
Guys,
Trying to work out what could be causing this problem. I have replaced the MAF and replaced the harness.
I don't have the clamps on my intake (Lexus charges $13 each for them) so I haven't gotten around to ordering them. Do you think this could be throwing the code if it is letting uncalculated arflow in there>>?
Any other ideas?
Thanks,
Jonny
Any other ideas?
Thanks,
Jonny
Just buy a clamp from Home Depot or your local hardware store. Shouldn't be any more than $3-4. It might not match every other clamp, but you're just troubleshooting at this point so there's no point in spending $13 for a metal ring from Lexus that might or might not solve the problem.
If you lived near me, I have a box full of clamps from my turbo project. T-Bolt clamps, worm screw clamp, metal fastening clamp, you name it lol. I wouldn't mind giving you one or two but with shipping costs so high...I think you would be better to just pick it up locally
Will keep you guys posted,
Jonny
Don't laugh, but gas cap gasket??? Just throwing something out there. I had a code(forgot the number but similar) and when I brought it in for an oil change at lexus they put a new gasket on and no more code. They also tried tightening it all the way first, but that didn't work.
No luck
Anyone else have any ideas before I go insane?? I need to get this taken care of. Hard to sell a car with a CEL that sporadically comes on and off.
Jonny
FYI - I have a 98 but my MAF harness got damaged so I bought a harness from a 99 which has different colors.
I have found an aftermarket MAF locally. I will install it today and if it fixes the problem I will bring it back and buy yours. Cool?
Jonny
I know the white with red and the brown are the sensor wires. What I need to find out is what color the sensor wires are on the 99 GS400 so I can make sure I have it wired in correctly.
Basically I have 98 wiring attached to 99 wiring and I need to make sure I have them connected correctly because the colors are different.
Jonny
