check engine light p0141?
my car recently threw a code and i had a scanner to find out the code and this seem to be the problem. but i dont get what its say.
P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
bank 1 sensor 2?
bank 1 sensor 2?
they're just coded that way so because obdII codes are all universal between ALL vehicles... so a P0141 is the same code between a lexus and a kia...
replace the faulty oxygen sensor and then reset your light... it should fix it..
i got this error code too, the guy at autozone said its the O2 censor like you said. but he wasnt sure if it was the o2 sensors taht came before or after the convertor. does anyone know which one it could be? also how much would this run to get fixed?
