Help-trying to install a new headunit
Hello guys( and the occasional gals). I am trying to put an aftermarkey stereo in my 99 gs300. LCD is out on factory one. Anyways. I found plaenty of dash kits but I was told no wiring harness is in existence for this model of car. Anyone ever hardwire an aftermarket radio in? Please help. I need to know which wire is is which? lol..sounds real funny but with a factory amp I just want to be sure. also a wiring diagram would be helpful. Thanks.
if you swap out your factory stereo to aftermarket, you will lose your factory sub. no one on here knows how to make the factory sub work yet, trust me i've asked around... you will have to get a regular 1990+ toyota harness and extend the wires so it is long enough to be at the stereo area. the factory toyota plugs are plugged into your factory amp (located behind the glove box to the right) so that is where you need to unplug the factory plugs and plug them into the toyota harness.
how do i get the old amp out or just get behind it with out tearing something up? also is it pretty much plug and play..like memory wire, factory speakers needs to be rewired or anything? please help. if anyone has put an aftermarket headunit or has a link to a write up please help!
how do i get the old amp out or just get behind it with out tearing something up? also is it pretty much plug and play..like memory wire, factory speakers needs to be rewired or anything? please help. if anyone has put an aftermarket headunit or has a link to a write up please help!![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
I spent a few days searching for related info on CL. Take a look at these threads:
https://www.clublexus.com/forums/sho...wiring+harness
https://www.clublexus.com/forums/sho...tock+amplifier
good luck.
GS Wiring Diagram:
http://lexusmodz.netfirms.com/GS_DIY/stereo
well I did it. Put in a single din unit blaupunkt today.(laugh , I am Poor). Somewhat dissappointed with it cuz it just does look as cool. But I did wire it up for a future amp to reuse the factory sub. thanks for all those that posted help.
redbarron
SC- 1st Gen (1992-2000)
06-18-11 08:23 AM
lexusscturbo
15
09-29-08 10:17 AM
