using VSC when there is snow?
Do any of you guys do it?
I almost got plowed today because I was making a right turn and put on the gas and it wasn't going anywhere. By the time I figured out what the heck was wrong.. a car was coming through the intersection. Luckily I was able to shut it off and it spun a little (prob cause I was still trying to give it a little gas but it was much better than when I had the VSC on).
I don't feel very comfortable when VSC on now after this incident. Have any of you guys run into the same problem?
It can save your a$$ if you know when to use it and when to turn it of. Sometimes you need wheelspin and that's when you want to turn it off. I got stuck at a light today because the VSC wasn't allowing enough wheelspin for me to get the car rolling from a dead stop
if you had an LSD, it'd really really help...
VSC is only there to keep your car going where the steering tires are directing it... it's nanny mode... it doesn't exactly do what most drivers desire their cars to do...
Yeah.. I think I will leave it off for now on.. regardless. I am pretty sure I can feel or hear if my wheels are spinning. I wonder how many people have got into accidents because they pulled out into traffic and realized they weren't going anywhere.
The rear end on the GS can step out VERY easily, I would leave the VSC on and turn it off when you really need it. When it's snowing out isn't really the time to be making turns where you're cutting it so close you'll be in trouble if you can't accelerate immediately
In crappy weather you should be giving yourself tons of room, no matter if vsc is on or off. If you almost got hit because you didn't "take off" then you should have/could have waited for a better oportunity.
uh.. that's why I was asking the question in the first place.. I gave what I thought was plenty of room and got in a situation where I didn't know what was happening with my car. I never had this issue with any one of my previous cars. A problem I am sure a lot of people that experience VSC in the snow for the first time probably go through. The weather wasn't "crappy" either. It was perfectly clear outside.. except there was slush that caused VSC to kick in... and that was only after I was already in the intersection... oh and it wasn't because "I" didn't take off it was that the "car" wouldn't take off.
Any car with traction controll will do this in certain conditions...the older the trac-system is...the worse it is...you should try the TRAC-system in the mkIV Supra...that system could REALLY get you into trouble
BUT...as has been stated earlier in this thread...having a good LSD will help
does getting an LSD affect the VSC?? i have been wanting to put on on to my gs but not sure if VSC will still work properly or the same after the installation of a LSD.
I had something to that effect happen yesterday while going up my driveway. I just put the car in reverse and with some gravity, I then put the car in drive and was able to drive up.
My GS is the first car that I have with some form of a traction control system. I'm still totally not clear how this system works. All I know is yesterday driving through the snow & ice, various times I heard what sounded like a clicking noise and the orange light (the car with the skid lines) light up on the dash. Mind you that the VSC was on as always and I had the car set to ECT/Snow mode. I guess it helped for the most part but the back did fishtail a little bit while on the road. The fishtail I blame for still having my low-profile tires on which both tires tread is not all that great. Not totally worn but part of Abe's head on the penny test was still covered. So can anyone please quickly in a nutshell explain what the car does when it senses slippage. Thanks!!
I hit a patch of black ice on Tuesday and between me trying to steer out of it and VSC hitting the brake on the right tires saved my GS.
You should also have it in snow mode so it doesn't use first gear. This really helps in slippery conditions. IMO VSC won't kick on as much.
i took out one of my drivers side abs sensor so i never have traction control, i think that traction control is dangerous it give out too much when you wanna have fun or are in a tricky situation.
