Dude I found moistures in my passenger Headlight housing. do they go bad..are they easy to remove? Is there a write up to how to remove the headlight housing? plz help.
Try putting a nice bead of silicone sealant around the housing. I had this problem when I did my retrofit so I put some silicone sealant and it fixed the problem right up.
I do see droplets inside my light housing. Plz help. Is it shot? Should I order another one or can I still reseal them? plz help. Also some quick instructions on how to remove the entire housing plz.
It's a pretty long process to pull the lights out and reseal. Not quick instructions. If you're not too much of a DIY guy...I would recommend you buy another set.
What does a new set of headlight housing's cost? I really only need the driver's side low beam headlight housing and wondered what it would cost to buy and how much labor will I be charged?
You really don't need to take them off. Just put silicone around the top edge of the housing. Take a blow dryer and dry the water that's already in there. If that doesn't work then you'll probably have to take the headlight out and pull it apart. Taking the headlight off the car is the hardest part. Opening it up will be easy compared to taking it off.
