1999 gs400 stock navi that plays dvd?
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
It does not play DVDs (is hard drive based). I believe you can get some aftermarket devices to play video on your nav, but the 98 - 00 screen resolution is not great.
You can replace it with aftermarket, but you will have to source a non-navigation AC control unit as the navi cars control their AC / heat, etc through the nav screen.
you can try this:
http://cgi.ebay.com/Lexus-GS-300-400...QQcmdZViewItem
it says its for 98's and 99's although I agree that the screen on our cars have pretty bad res.
https://www.clublexus.com/forums/sho...d.php?t=219060
So, as Dave and others mentioned, if you source an NON navi AC control unit, is it plug and play or will you have to custom the entire wiring and connectors? The reason I ask is I too probably would go for a non navi so I can replace the head unit, but if I find a good navi car that I can't pass up I may have to buy it
I just want to make sure the NON navi AC control retrofit will not be too involving.
Forum Administrator
Vic, I don't know. I doubt you are going to find too many folks experienced with that because if they have Nav they typically don't go backwards to put in a non-Nav AC control... those that have pulled them out (only a couple) have put in newer version Navigation from GS430.
