VSC light, VSC off, ABS light all on
I searched but couldn't find anything similar to mine, except a few about vsc and cel on.
in my situation I have NO cel light on, but the vsc, vsc off, AND abs light are on. It started tonight while driving home, I went over a little bump and the lights all came on at the same time.
I have disconnected the battery, but that didn't get rid of it. I am now trying to reset the ECU by pulling the 20A fuse, so hopefully that'll clear it.
Now if that doesn't work, what could it be? dirty ABS sensor? loose ABS? I really hope I don't need to replace anything.
The front and rear sways are installed properly, I have Daizen sways and they are installed following the stock placement (except the rear where you're required to reverse the end links) so i'm pretty sure they aren't backwards.
Thanks
Thanks
Thanks
Thanks
i have that very same problem. I have a 99 gs300. same symptoms. where are the abs sensors and wires located. in or beside the calibur perhaps. also what should i look for, just broken wires around it? plz help.
you probably won't see the actual broken wires since they're inside a sheath or casing, but you can technically expose the wires and solder them back together, which I may need to do.
I got the same problem with all lights on. but mine started when i installed a new stereo and unplugged the switches and for got to reconnect them. now that they are plugged back up, the lights wont turn off on gauge cluster.
Whoever needs a guide on how to repair the ABS sensor cable...here's my DIY site for it
http://www.projectgs.com/diy/SuspBrake/ABSVSC/index.htm
Here's the main page with a few more guides if you're interested. http://www.projectgs.com/diy/
