Best way to fix a crack on a sideskirt
it was made by bondo.
this was the one i used.
http://www.automotivetouchup.com/sto...epair_kit.aspx
i used to manufacture polyurethane products.. What we recommend to our customers was plastic epoxy (like the one on the posted above). There are many different types of plastic epoxies to choose from but I'm not sure which would be best.. Do not use body filler. Body fillers do not chemically bond to polyurethane and will show signs of cracking from stress and heat in time.. You do not want to repair and paint it and find out a couple months later that you will have to redo the whole process.. And do not melt the polyurethane.. Polyurethane processes is a chemical reaction of two compounds joining on a molecular level.. Melting the material will only burn it and cause more damage and weaken it at the same time..
Thanks for the great info inspired. i was about to use a solder iron haha, thanks for the heads up.
i will definately go get a bottle of the plastic epoxy!
Oh.. By the way, I recommend you make the area rough where you apply the epoxy.. Use a 40-60 grit sand paper to make grooves into the polyurethane.. I recommend this because there will be more surface area for the epoxy to grip on and makes it stronger.. My guess is that the sideskirts have a smooth crack on it.. Am i correct?
the crack itself is not a straight line if thats what you mean by smooth?
its kinda on the corner of the sideskirt like a 90 degree angle. kinda hard for me to explain, but ill snap a pic of it tomorrow and show you.
when you say, make the area rough, are you talking about the crack itself, or the area surrounding the crack?
bjnzzzle
12-11-16 04:56 PM
