DIY- $10-5 minute power steering fluid change.
Old 02-27-07, 07:02 PM
chuckb
chuckb's Avatar
Originally Posted by corkycal
is all toyota ATF the same? I used type iv ATF which is the same stuff for our tranny.
It's not all the same. You are supposed to use Dextron, not Type IV.
What's the difference, I don't know.
Old 02-28-07, 08:21 AM
corkycal
corkycal's Avatar
thanks for the clearification chuck.
i called toyota and they said they don't carry dexron anylonger. they mentioned that they have toyota power steering fluid.
i getting a bit confused, should i just buy the toyota power steering fluid or just go to my local auto store for dexron II or III?
Old 02-28-07, 08:33 AM
chuckb
chuckb's Avatar
That's odd because I just got that quart of Toyota Dextron last week at the dealer. I'm sure any quality Dextron II/III will work fine.
Old 02-28-07, 10:20 AM
Lubs
Lubs's Avatar
Would this tactic work for the brake fluid reservoir and help clean the fluid? I would think the lines keep mostly old fluid, but would it help at all?
I'm afraid to do a DIY bleed because I've read multiple different ways to tackle the problem (how many brake pumps, key in or out, etc.).
Back on topic: I'm going to get right on this when it gets a little warmer out. Thanks for the DIY ChuckB. But the bathroom sink, how could you?
Old 02-28-07, 11:06 AM
Lexmex
Super Moderator
Lexmex's Avatar
A service guy at a Toyota down here where I go to pick up my Type-IV told me they had been using the Type-IV for PSF though he remembers when they were using the the Mobil 1 ATF little while back. However, Toyota has only been down here since about early 2002, so older vehicles might be different.
Old 04-08-07, 06:05 PM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
Is it bad that I use valvoline maxlife powersteering fluid and not OEM? thx
Old 04-08-07, 07:06 PM
Caoboy
Caoboy's Avatar
it is when you are supposed to use ATF rather than powersteering fluid!
Old 04-08-07, 07:13 PM
Lexmex
Super Moderator
Lexmex's Avatar
I used to use the Valvoline Synpower PSF, but now I use Mobil 1 ATF.
Old 04-08-07, 07:40 PM
Wald GS
Wald GS's Avatar
thanks guys. What effects are present when wrong fluids are used? thanks
Old 04-08-07, 08:28 PM
LEXUS_KID
LEXUS_KID's Avatar
Chuck you get 3 of these
Old 04-08-07, 10:29 PM
Caoboy
Caoboy's Avatar
it's like putting vegetable oil in your motor. or putting transmission oil in your motor. it's not the right stuff, and will wear everything out quicker.
Old 04-08-07, 11:56 PM
Wald GS
Wald GS's Avatar
Is there any non oem, that is similar to oem that I can buy at autozone? thx
Old 04-09-07, 01:02 AM
Caoboy
Caoboy's Avatar
dextron type II/III ATF. no point though, it only costs a few bucks more for the OEM stuff.
Old 04-09-07, 01:08 AM
Wald GS
Wald GS's Avatar
Autozone is 3 min from me. Nearest lexus dealer is 20 minutes.
Old 05-11-07, 10:52 AM
pingu
pingu's Avatar
The extra 20 minutes is worth the drive
Quick Reply: DIY- $10-5 minute power steering fluid change.
