DIY- $10-5 minute power steering fluid change.
Old 05-12-07, 10:49 AM
  #31
blue99GS4
blue99GS4's Avatar
Nice write up. Did mine yesterday. Thanks.
Old 05-30-07, 03:32 PM
  #32
olddog
olddog's Avatar
isn't there a plug, screw or something to take off and all the oil drains out completely?
Old 05-30-07, 07:36 PM
  #33
sjpobox
sjpobox's Avatar
Originally Posted by Wald GS
thanks guys. What effects are present when wrong fluids are used? thanks
Hi, we use valvoline at the dealership I work at, just make sure the bottle you used or going to use says meets oem standards. I believe ours says ford, chevy, toyota, lexus.
Old 05-30-07, 07:39 PM
  #34
sjpobox
sjpobox's Avatar
Originally Posted by RacerLex
Thanks chuckb, I love DIY posts like these, thanks for sharing! Saves time and money (which can be applied to mods)!
If you want to speed up the process, take this approach:
1. Siphon old fluid
2. Pour new fluid
3. Turn steering wheel lock-to-lock 5 times
Repeat steps 1-3 about three to five times and you should only have new fluid left.
Yes and make sure you do not puncture or push in the metal screen in the middle of the resevoir.
Old 05-30-07, 10:05 PM
  #35
olddog
olddog's Avatar
How many bottles of fluid would one require for this DIY?
Old 05-31-07, 07:55 PM
  #36
LexFather
Guest
Posts: n/a
Thanks dude!!!
Old 05-31-07, 08:04 PM
  #37
GSteg
GSteg's Avatar
1 quart should be enough. The reservoir is small and the fluid line itself to the pump is also small. I was able to get the fluid to the new red color by the 4th trial. I had some left to do one more car in the family.
Old 11-21-07, 01:41 AM
  #38
movinquick
movinquick's Avatar
props on the write up. makes the job too easy.
Old 03-25-08, 01:49 AM
  #39
RX729
RX729's Avatar
good diy, did mine yesteday...
Old 03-25-08, 06:46 AM
  #40
Chris2
Chris2's Avatar
Good write and very helpful. Easy DIY for guys like me.
Old 03-25-08, 10:45 AM
  #41
GSoup
GSoup's Avatar
Similar DIY has been discussed before... Quicker method on Post #23
https://www.clublexus.com/forums/sho...ht=replacement
Old 03-25-08, 12:31 PM
  #42
UncleRay
UncleRay's Avatar
I used an old vacuum that was just sitting around to suck out the stuff ^_^... Boy I tell ya, that oil was FIIIIIIILTHY!!! Thanks for the awesome DIY!
Old 06-06-08, 10:16 AM
  #43
RX729
RX729's Avatar
did mine today and it was pretty dirty too. Nice write up....
Old 01-19-10, 07:41 PM
  #44
kennylexsc
kennylexsc's Avatar
thanks for writting this tread, it looks very easy just to change the ps fluid, but I have heard that the air bubble will get in or do a bleed right, anyone knows this is true or not,
no need to do a bleed right, just pump out and pour new ps fluid, correct me or any ideas on this would help every body
thanks
Old 01-19-10, 08:15 PM
  #45
airahcaz
airahcaz's Avatar
isn't a few bucks to do at a quick lube shop? and they continue to run it till you actually see the fluid changing to clear red... takes a few minutes, in and out
I can appreciate DIY's, but this is a one time event?
Quick Reply: DIY- $10-5 minute power steering fluid change.
