Side marker DIY install?
Does anyone know where I can find a complete write up for the side marker DIY? I found this http://lexusmodz.netfirms.com/GS_DIY...ide/index.html but it's not very useful because he doesn't really explain the steps. I was just wondering, should you force the reflector out from the inside or do you have to pry it out at the same time or what. I dont want to mess anything up since I'm a nooby at DIY's. Any ideas would really help a lot. Thanks in advance.
That guy spent WAY TOO MUCH TIME and effort doing it that way. All you have do do is remove the fog lights, which are held in with 2 screws. Then just stick your hand in there and you unbolt the nuts holding the side marker in with a socket wrench. I don't remember what size, but they're small. You just have to stick your wrench in there and feel for them since you can't see. It should take you no more than 10 minutes for both sides. I did mine and it was really easy.
Goodluck!
Goodluck!
here's the only tool you will ever need...
![](https://www.clublexus.com/gallery/data/500/search1.jpg)
All jokes aside there are several write ups regarding this. Please utilize the search function before creathing a thread. Thanks.
Yeah I looked... I couldn't find any good info on it. If I could, I prefer not to waste people's time.
Nothing needs to be forced. Just remove the single screw that is holding the fender lining and pull it back. Stick your hand in there and you can feel the nuts on the back of the light. Remove those nuts (two on each light) and the sidemarker will pop right out. Nothing much to it.
I do it a different way. Just remove both foglights. Stick your hand into the foglight hole and you should be able to feel the sidemarkers inside the bumpers. Just take a 10mm wrench and remove the bolts. Rotate the connector and the bulb will come out. Reinstall everything in reverse order. Good luck!
https://www.clublexus.com/forums/sho...rs+install+diy
1. Your going to need an 10 mm socket or open end wrench.
2. Remove the foglight
3. stick your hand in and feel for the 2 nuts on the side marker. One on each side.
4. Just remove the nuts and pop it out or it will fall out.
5. disconnect bulb.
6. clean area where sidemarker was at (why not...)
7 connect bulb to new sidemarker.
8. Just do the reverse of removal.
Should take you about 15 mins max. Very simple to do.
Going through the Fogs is the easiest way, there's 2 10mm bolts that per side, you can basically feel for it and take them out with a help of a wrench to loosen... passenger side might be a lil bit more difficult due to less room to reach in...
pieisgude
136
03-29-22 07:28 AM
