I'm not getting help in the other section...can someone here help me please?
I've gotten no responses and little view in the audio section so can someone help me here please?
I've got an '02 GS with stock radio like this...
I'm sure its been discussed before, but I couldn't find anything. Can I install some subwoofers and an amp to my factory radio and speakers without a problem? I only ask because I remember it was a real pain in the butt in my Cobra with the factory Ford system. In order to install subwoofers I HAD to install new speakers too inorder for everything to work.
I just wanna put 2 12"s or 2 10"s in the trunk with a nice amp. Just simple, I don't wanna change factory radio or speakers at all if possible. I dunno if it matters, but I've also got my Sirius radio hardwired to the radio, and installed in the ashtray compartment.
Thanks in advance for any help, I really appreciate it!
Jim
Jim
It will work, just get your hands on a line convertor.
This converts the stock speaker signal level into a more user-friendly after market amplifier input phono level connector.
I got rid of my stock radio for this:
See: http://sr1.clublexus.com/forums/showthread.php?t=268152
Once you get power to your boot (aka trunk), the install should be simple as you have a high-level sub signal there already. As I said above all you need is a converter from a hi to low signal.
Jim
Jim
Hey, GS-Ireland which front end are you using? Kinda looks like streetdeck but I can't say for sure. I run a laptop in my car thats hidden under the passenger seat and my LCD in the dash looks exactly like yours. Only difference is that I have a little gap between the lcd and the edge of the bezel.
EDIT: Ah, I just looked at that page and you said you're using Centrafuse. Are you using the beta? I don't think the final release is out yet.
