fan is always on when car is running?(cooling radiator)
#31
guys.. the answer is the fan relay..
If u dont have one connected.. ur fan will run constant.
Lower pass side on the radiator i believe.. check that the relay is connected or that u even have one there..
If not.. go to autozone and hook one up.. cost like around 60 to 70 bucksss
it should solve ur problem
went thru this.. a while ago..
Can you show me the diagram where is the location of the relay and what is the relay look like, greatly appreciated.
Thank you .
bigjussin
11-11-12 12:28 PM
