fan is always on when car is running?(cooling radiator)
why would the fan seem to be running most of the time im driving. i've had the car for about 7mos now and i just began to hear the fan running constantly. it doesn't run while the car is off and i don't drive hard all the time. can anyone give advice?
ps... i do live in florida and its not to hot here now in jacksonville and ive heard the fan for about 3wks.
luckeygirl (07-17-21)
Hi I have a Lexus ES300 and the fun goes on as soon as the car is turned on (even when A/C is off) and when the car is not on, the fan still remains on for a while. I see a lot of posts and suggestions - but no one has stated what the cause of the problem is. Can someone please post what the root of the problem is. Thanks a million.
There is a sensor at the bottom of the radiator on the driver side. Unplug the connector to it and see if the fans stop. It may have gone bad and is holding a closed connection. If it stops replace the sensor, if it doesn't stop the relay could be stuck/sticking like previously mentioned.
guys.. the answer is the fan relay..
If u dont have one connected.. ur fan will run constant.
Lower pass side on the radiator i believe.. check that the relay is connected or that u even have one there..
If not.. go to autozone and hook one up.. cost like around 60 to 70 bucksss
it should solve ur problem
went thru this.. a while ago..
Thanks! But i have checked the relays and switched them with my other Gs and is still the same.
I have also tried the engine ecu and is still the same. There are some people who have checked the relays and switched them. Also changed the engine coolant, fan switch and still fan on. What the hells going on with these cars? This is the strangest problem i have encountered. Please someone out there who have went thru this, Please give me some answers? Thank you!
