NEW Nagisa Auto Suspension parts for GS300!
Former Vendor
![](http://www.more-japan.com/skin1/images/info_nams.jpg)
![](http://www.more-japan.com/files/t_18360.jpg)
Tie Rod Ends
These pillowball tie rod ends are designed to hinder the effects of bump steer when the front wheels toe out excessively over bumps.
The Nagisa Auto tie rod ends will allow significant adjustment and correction of front end steering and suspension geometry.
![](http://www.more-japan.com/files/t_18375.jpg)
Front Camber Adapter
Lowers vehicle 20mm
Connects to lower arm
Adds negative camber angle 2.5 - 3.0 degrees
![](http://www.more-japan.com/files/t_18362.jpg)
Front Tension Rods
Replaces stock tension rods with reinforced units with solid pillowball ends.
May be used for Caster angle changes.
Factory tension rods use a rubber bushing which tends to wear quickly and affect handling stability. Adjustable pillowball ends allow for adjustment beyond factory settings.
Multi-link suspension pieces feature high quality construction and durable spherical pillow ball ends, which eliminates factory rubber bushing type suspension arms.
*For pricing inquiries please contact the forum sponsored vendors.
*For dealer inquiries please contact info@more-japan.com or call toll free at 1-888-560-4800.
Tanabe USA
09-06-07 09:25 PM
Tanabe USA
SC- 1st Gen (1992-2000)
04-10-07 05:04 PM
Tanabe USA
12
04-02-07 06:43 PM
